atf/mtf
Old Oct 13, 2005 | 09:27 PM
AndrewNguyen's Avatar
AndrewNguyen
Default atf/mtf
does gm put automatic transmission fluid in manual transmissions?
Old Oct 13, 2005 | 09:32 PM
devnull's Avatar
devnull
Scientific Negotiator
St. Jude Donor '07-'08-'10, '14
Dunno. Hey, aren't you that poker dude???
Old Oct 13, 2005 | 09:36 PM
AndrewNguyen
no im not i cant even play it
rws.1's Avatar
rws.1
That's what I put in....
Old Oct 14, 2005 | 10:54 AM
Mike McCoy's Avatar
Mike McCoy
The manual transmission fluid used in your vette is the same as used in the A4. Most all manual aluminum transmissions and aluminum transfer cases (4x4's) in modern cars and trucks use automatic transmission fluid.
Old Oct 14, 2005 | 11:08 AM
TOOGECKO's Avatar
TOOGECKO
I was looking at this yesterday. I want to change the fluid in my '04 Z next oil change to a synthetic, probably Royal Purple, Redline or Amsoil. Any suggestions? How much is needed?
Old Oct 14, 2005 | 11:15 AM
TOOGECKO's Avatar
TOOGECKO
Old Oct 14, 2005 | 11:39 AM
MiamiCowboy's Avatar
MiamiCowboy
8 pints. Fill and drain plugs are torqued to 20 ft-lbs. If I remember correctly you need a deep 22mm socket to remove the fill plug because it has a sending unit attached to it.
Old Oct 15, 2005 | 01:01 AM
C66 Racing's Avatar
C66 Racing
Premium Supporting Vendor
For the C5/Z06 manual transmissions, a fluid meeting Dexron III standards is required. This fluid is normally an ATF. The C4 is different. Not sure about the C6.
I have been using the AMSOIL ATF on the track for the past two seasons and have had no transmission issues (still on my original stock tranny).
Tranny will take just under 4 quarts. 3.5-3.75 is normal for most drain and refills.
AMSOIL Preferred Customer Program
__________________
C66 Racing #66 NASA ST2, SCCA T2
AMSOIL Dealer (Forum Vendor)
AMSOIL Preferred Customer Program (Members buy at Wholesale - a savings of about 25%)
To atf/mtf
