I use a 4:1 dilution of water:Simple Green sprayed onto a COLD engine.
Let is soak 5 minutes and then powerwash.
I covered the alternator and the battery with plastic(grocery store) bags.
If it is warm and sunny let it dry on its own. If it needs help use compressed air or a leaf blower.
Did the whole engine compartment including the hood liner . Note don't try and brush the hoodliner. Either vaccuum it or spray, powerwash and let drip dry.
St. Jude Donor '06-'07-'08-'09-'10,'13-'14,'19-'20-'21-'22
With every car I've owned, vette included, I run up to the local power wash and have a field day. Try to avoid spraying the alternator and you're fine. It's usually mostly dry by time I drive home, and I towel off the rest.
The engine gets wet when when you drive in the rain or through a puddle, the power wash won't hurt it, just don't soak the alternator or air filter.
Have it warm to begin with, not hot so that steam sizzles off, but warm enough to have a sensation of warmth coming off it.
Spray your simple green, hose it off and then go drive it. If you don't drive it then you will probably end up with water spots or it will take forever to dry. I don't think it will rack your block because the engine will already be mildy warm, and so will the water and as the engine heats up, the water won't be that much colder.
I would Not recommend any power washing or full stream water. Many people have had major issues with contaminated knock sensors.
My engine looks as good as the day I bought it.. just a little wipe down with some Zaino gloss enhancer..my car is six years old and has over 60,000 miles on it...
I take the shop vac to mine at least once a week. Takes about five mins max and gets all the sand, dust, etc without the worry and mess of spraying water in my engine compartment.
Just be careful when putting Simple Green on aluminum. The alkalinity of Simple Green can accelerate the corrosion process.
this caused a massive problem in the F-16 air force community w/ all the crew chiefs using simple green on the landing gear, led to serious corrosion and a stop to the green stuff
here are a few recent pics....
as usual, ET is spot on. I never understood the powerwash fascination under the hood. I have a '97 with 59,000 miles. I have never repeat never even sprayed water under my hood. I wash the car and simply wipe off the excess water with a towel and use some Armorall cleaning wipes and detailing wipes to brighten things up. I do recommend adding a hood seal as I find that it really keeps the dust and debris down to a minimum. Anyway, to each their own, but here's mine.
I also use Swiffer dusters to get into the hard to reach places. Works great. 20,000 miles and engine looks the same as the day I brought it home.
THis is no flame on anyone, but I have never understood the powerwash under the hood either... you could not pay me enough money to do that on my car. Too many electrical compenents, grounds etc that the water could get on to. These cars are already sensitive enough electrically without blasting XXX PSI of water...no thanks.
I would rather use a much safer method as others have said here.
Have a friend with a '89 and he uses the tire foam mixed in a gallon of water then douses the entire engine compartment. He has the most fantastic looking engine compartment I've seen on a C4.
