[Z06] Quick Lowering Question
two quick questions:
1. with 2/3's of the front bushings gone, i can still achieve the best look (with 1/4-1/2 inch rake) on stock rear bolts? or do i have to change the bolts?
2. for those that cut that much from the front, how much did you lower the rear, approx, to achieve that look?
THANKS
check this out. I believe he cut the front and rear bushings but left the
stock bolts intact. Good luck!
http://www.z06vette.com/forums/showt...hlight=lowered
THANKS
also, how/where do you measure to find the rake?
one thing is strange though, the passenger side, before adjusting, was far lower than the drivers side. i'd say it was a half an inch lower, with the same measurements on all 4 bolts. this happen to anyone else?
Good post and good info thanks brothers! Dave
Here are some before and after pics. The before are lowered on stock bolts. The last 2 pics with the car outside are the newest with the most recent lowering. Hope this helps
http://www.villagephotos.com/pubbrow...der_id=1430547
Dave
its a bad pic but the only one i have right now...
it on the ramp. He threw some boards down and got it done, but he
charged me a few extra bucks for his trouble. After it was on the ramp
there were no problems. In his words, "It lined up real sweet." Oil
changes/maintenance at the dealership are another matter. Those
guys aren't willing to take the extra step (boards, etc.); I guess they
don't have time. When I took it in for the leaking rear diff. they charged
me an extra hour of labor to get it on the rack using boards. I'm going
to be needing brakes soon, so I'm seriously thinking about raising it back
up about an inch so I won't have to deal with all their BS whining about
how low it is. The last oil change was also a nightmare. New tires are
problematic too, but the Discount Tire guys in my area are cool and
they deal with it (use blocks, etc.) and don't complain. That's only the
beginning. You also can't drive it just anywhere unless you don't care
about how the rockers look. But, on the flip side, it's a blast to drive
when it's slammed. If I didn't have to deal with the dealership I'd be
fine. I can be careful on the roads and avoid high-centering situations.
I haven't been able to control what happens at the dealer. Good luck.
