Headlight madness.. a DIY mod, look inside
Old Oct 16, 2005 | 09:12 AM
NOT-MEE's Avatar
NOT-MEE
Cruise-In V Veteran
Cruise-In VI Veteran
Cruise-In VII Veteran
St. Jude Donor '06-'07
Just FYI the 9005 high beam bulb was not designed as a low beam bulb more than likely you will burn it out very quickly.
The reflector design is what controls the beam pattern not the bulb.
The bulb just produces the light.YOU might wannt to click here for bulb info
Old Oct 16, 2005 | 09:17 AM
bcseitz's Avatar
bcseitz
Great Info. ! Thanks
[IMG][/IMG]
Old Oct 16, 2005 | 09:19 AM
Dark-Knight's Avatar
Dark-Knight
Looking forward to your next post!
Old Oct 16, 2005 | 10:31 AM
C6~Missle's Avatar
C6~Missle
I checked into this before the mod. These bulbs are considered "standard" wattage and have the same life expectancy as low beams. They only draw 10 watts more than the low beams yet put out 1700 lumens compared to 1000 for the low.
Old Oct 16, 2005 | 11:32 AM
debmwb's Avatar
debmwb
Having the same issue as you, I changed my bulbs over to SilverStars. Muuuuuch better!
Old Oct 24, 2005 | 08:50 PM
C6~Missle's Avatar
C6~Missle
ttt... link for the mod is at the top of this thread
