Swapping Exhausts [HELP]
Just doesn't look like there would be enough room to do all that twisting and bending around as opposed to having a lift with more room to twist and turn, especially downward.
Time of the essence to get the stock OEM off and the B&B system on. The B&B is much easier, because there is a clamp on the back side that can be taken off so it comes out as two pieces - the over the hoop pipe then connect to the muffler via the clamps.
Any help ideas on this?
If you cut the old system off you do not need much hight. I kept my old system a few years then threw away.
Your right the BB go on much easier. I had them on my C5Vert
I will try to dig up a picture when I removed my Z06 exhaust system in my garage just to show how high it has to be.
Edited: added picture
I've found a garage with a lift. Could the stock OEM be taken off, in say, 15-20 minutes? There are just two bolts on the flange in front of the axle, remove the bolt for anti sway bar, then roll that down and out of the way, then then muffler hangers.
1/2 hour cover it?
1/2 hour cover it?
- City Garage DFW area....
- a place I would never have do any serious work on anything
-- but what the heck - just needed their lift(s)
They agreed to "do the work" while I watched. (Yeah Right) It was apparent they had never lifted a vette, so I aligned the lift to the lifting points - put some old rubber bushing spacers so no damage to the sills, and up it/they went. Then while I was supposed to be merely 'an observer', started with the wrenches and off it came - incredibly easy. Then the other car,.. got them swapped and back down. I think it made the mechanics day when I let him drive one of the 2 home with me - about 1 mile away!
They were amazed how easy it was to do. And, YES... needed every bit of the length of the exhaust from the flange back over axle hoop to remove the stock (folded down the sway bar) and was done with both cars in about an 1 hour. - Sunday Corvette tax charge? Only $60 for basically the use of 2 lifts and someone to help me hold stuff while taking it off and making the swap.
I put 45 lbs torque on the top bolt sway bar, and 75 lbs on the bottom bolt, cause I forget what the torque values are
. Easy to correct if they are wrong.Thanks for the tips!
Thanks for the correct values. Been looking all over the place for the correct values. Saw them someplace, but forgot to bookmark them!
Somebody said 3 ft. clearance. They are correct. Get it high enough and its easy as cake.
2 hours to do the whole job. 1 1/2 hours for the jacking. Half hour for the disassembly/install.
Now I need to find someone who can use the old exhaust. Doesn't look like they go on ebay.
D
