[Z06] More HELP
Old Oct 17, 2005 | 06:08 PM
RB6's Avatar
RB6
Cruising
Default More HELP
Brief background...the other day I installed the C5 Twin Flow Intake system and had issues as a result, when i started the engine to examine my handywork and admire my new results I found the engine was idling was real rough and would barely stay running, I had leaks in my install, I fixed all the leaks...I took it out to drive it to work this morning it ran really good at high speeds, but when stopped at a red light the ideling was still not what I thought it should be, on the way home I get the "CHECK" light lights, the check emmissions i think it is. It is in the left middle of the speedometer. When I get home I check the codes, intitially in the PCM module P0171 and P0174 are there. I disconnect the MAF and the engine idles much better, when I connect it back up it almost stalls out. I check the codes again and get P0068 and P0102....What is going on here? Is the MAF malfunctioning?
Old Oct 17, 2005 | 06:49 PM
User 81424's Avatar
User 81424
From post # 31 in the FAQ sticky
P0102 Mass Air Flow (MAF) Sensor Circuit Low Frequency
P0171 Fuel Trim System Lean Bank 1
P0172 Fuel Trim System Rich Bank 1
P0174 Fuel Trim System Lean Bank 2
Old Oct 17, 2005 | 07:07 PM
RB6's Avatar
RB6
Cruising
I looked at the list, but what does this mean, is the MAF gone bad?
To More HELP
