Functional Cove Vents
Old Oct 18, 2005 | 12:04 AM
sage666's Avatar
sage666
Default Functional Cove Vents
Would drilling some holes in the liner behind the cove vents allow them to work as functional heat extractors from the engine compartment?
Old Oct 18, 2005 | 12:09 AM
saniterium's Avatar
saniterium
If your car is not overheating, why worry about it?
Old Oct 18, 2005 | 02:26 AM
jdmvette's Avatar
jdmvette
Night Owl for life
i wouldnt drill them, that would be a waste of time.
you can remove both sides, but the passenger side has a computer located right underneath it.
i have read that the computer is watertight and sealed and it should be no problem to go without the cover.
i didnt remove it was because i dont think it really provides access to remove heat on the passenger side because it is sealed off by the battery surround and would only vent the battery area. the drivers side has an open path to the engine bay.
i did remove the driver side cover and after driving it and parking in the garage i could definately feel the heat coming out of the vent.
it is a very worthwile and functional mod. just be sure to get the cove screen covers.
Old Oct 18, 2005 | 10:34 AM
Mad_Maxxx's Avatar
Mad_Maxxx
Cruise-In VII Veteran
When you say "cove vents", are you talking about the side vents behind each front wheel?
Old Oct 18, 2005 | 10:46 AM
xlr8shn's Avatar
xlr8shn
Yes
Old Oct 18, 2005 | 11:47 AM
MyVetteDream's Avatar
MyVetteDream
From: HOW FAST WAS I GOING OFFICER? Los Angeles Hating GM Dealership Service Dept.'s Since Sept. 2004
St. Jude Donor '04-'05-'06-'07
They let air out of the engine bay...
Have you opened up the "IN" side yet?
Old Oct 18, 2005 | 11:55 AM
Yoggi's Avatar
Yoggi
Interesting topic
Old Oct 18, 2005 | 12:00 PM
mike101's Avatar
mike101
What do youy mean? by opening up the inside?
Old Oct 18, 2005 | 12:21 PM
MyVetteDream
I meant getting air into the engine bay... by either drilling 4- 1 inch holes through the fog light shrouds... or getting the pre-made ones from places like Mid America or Ecklers... or removing them all together. Of course you may want to put screens on after, so big debris will stay out.
I just figured if you want more air coming out, you may want more going in first.
Old Oct 18, 2005 | 01:24 PM
sage666's Avatar
sage666
Thanks to all for the info.
Old Oct 18, 2005 | 06:34 PM
edensknight's Avatar
edensknight
This was one of the first mods I performed on my C5. And, I did so knowing that I could have more air coming in through the now fully opened fog light insert sections above shroud, at speed, to my dual cone cold air intake for improved breathing. No trouble codes.
Also, JD, (above post), I am freaking proud of you, good buddy. Frankly, opening the side front fender cove vents is very helpful for reducing engine bay temps. And, I have had mine out for three years, having driven in some rather heavy winter season rain, with no unusual incidents, leaks, trouble codes, or, problems.
Old Oct 18, 2005 | 06:43 PM
rayncris's Avatar
rayncris
cool...sounds quite interesting. You know, you could always just have a set of short tube headers running out the 'cove holes'....get some flames goin....
Ray
To Functional Cove Vents
