Can I shut the "tire pressure low" alert of with a TECHII or some other way?
Are you trying to disable it for good? Then yes you would have to use a tech II. If you just want to stop it from dinging at you just hit the reset button when the alert comes on. You may have to do this several times or every now and then on a longer trip.
This worked for me.. Preasure of below 25lbs. Understand it comes on at 24lbs and below.. Scared the s%$^ out of me...
From: "It's 106 miles to Chicago, we've got a full tank of gas, half a pack of cigarettes, it's dark, and
St. Jude Donor '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17-‘18-'19
I understand the question - I just don't understand why.....
Many of the newer cars are starting to come with TPM's of some sort. I thought I read somewhere that the Fed was going to make them mandatory at some point stemming from the whole mess with the Ford Explorer and Firestone.
Here we are blessed with the vehicle that started offering them back nine years ago and we want to not utilize the technology. Your sensors could have easily been adapted to the new wheels. I think it's a safety advantage, especially with todays ultra-low profile tires, it's hard to tell visually when you have a low tire.
