Blackwing Questions
Old Oct 18, 2005 | 10:40 PM
Tigershark3's Avatar
Tigershark3
Default Blackwing Questions
I received my Blackwing from Corvettes of Houston today. Looks great but with the filter they shipped the Bellow Kit that's needed with 2001-2002 C5's - mine's a 1999. This bellow kit is described as a 3.75" straight sleeve and includes a hose clamp. Before I call the vendor I wanted to ask the forum members if the filter assembly itself is the same regardless of the year? Also, it looks like both ends of the Blackwing tie into the gromments that are on the car to help hold it..... Is that correct?
Thanks in advance for your help.
Old Oct 18, 2005 | 10:45 PM
rickko's Avatar
rickko
This might help ya' a little...
http://97vette.com/howto/blackwing/
..rickko..
Old Oct 18, 2005 | 10:53 PM
diyguy's Avatar
diyguy
Does this mod change anything in terms of fuel/air mixture? I presume increased airflow to the intake is less restrictive than OEM air filters.
Just curious if the computer will automatically compensate for proper fuel/air mix, yes?
Old Oct 18, 2005 | 11:04 PM
mvvette97's Avatar
mvvette97
St. Jude Donor '06-'07-'08-'09
Yes, drive it for a while so it can adjust.
Old Oct 19, 2005 | 03:41 AM
edensknight's Avatar
edensknight
Old Oct 19, 2005 | 09:20 AM
j3studio's Avatar
j3studio
Cruise-In V Veteran
St. Jude Donor '06
Took about 50 miles for us...
Old Oct 19, 2005 | 09:21 AM
COHMATT's Avatar
0COHMATT
Former Vendor
Yes, the filter is the same.
Old Oct 19, 2005 | 11:52 AM
GeorgieMporgie's Avatar
GeorgieMporgie
So what are you thoughts on the blackwing? Does it perform as expected? Better, Worse?
Old Oct 19, 2005 | 11:54 AM
bennettrp's Avatar
bennettrp
St. Jude Donor '06-'07-'08-'09-'10,'13-'14,'19-'20-'21-'22
works great for me.
Old Oct 19, 2005 | 12:17 PM
csexton's Avatar
csexton
All from me !
Chuck
Old Oct 19, 2005 | 12:35 PM
Tigershark3
I'm removing a K&N filter and replacing it with this Blackwing. When I bought the car I took the K&N off and cleaned and reoiled it. Seemed ok and the car ran well but the Blackwing appears to have a lot more surface area for air. I've not seen a K&N like mine offered for sale by any vette vendors..... Might be out there but I have not seen it.
Old Oct 19, 2005 | 12:51 PM
Blackwing works great on my car. Did not have to do anything except take off the old filter housing and install the Blackwing. I still use the same stock acordian piece on mine.
To Blackwing Questions
