Headlights dim slightly with window roll up
Old Oct 19, 2005 | 01:59 AM
dataporter's Avatar
dataporter
Default Headlights dim slightly with window roll up
On my 99 frc the Headlights dim slightly, but noticably, for a split second when the I roll the windows up. It happens from when the window is fully closed until I lift my finger off the switch. Is this normal? I have a new Optima battery and have no other electrical problems whatsoever.
thanks
Dave
Old Oct 19, 2005 | 02:02 AM
terlox's Avatar
terlox
I believe this is normal. My interior instrument lights dim ever so slightly when I turn on my fog lights.
Old Oct 19, 2005 | 02:04 AM
ericdwong's Avatar
ericdwong
Normal. It takes a tremendous amount of power to move an electric motor.
Old Oct 19, 2005 | 08:44 AM
striper's Avatar
striper
This is probably normal on most cars, not just Vettes. That moment when the window stops and the button is still held puts a lot of load on the entire system.
Old Oct 19, 2005 | 09:21 AM
WKMCD's Avatar
WKMCD
Normal
Old Oct 19, 2005 | 10:42 AM
kasper-pA-'s Avatar
kasper-pA-
St. Jude Donor '05, '14, '15
Mines does this as well, but I thought i read somewhere that when you swap out battery with a Red Top it doesn't do it anymore? anyone know if that's true?
kasp
Old Oct 19, 2005 | 10:52 AM
5.0_CJ's Avatar
5.0_CJ
It's a GM
at least its not like my mustang, if you held all 4 window buttons up, hit the brakes, had to headlights on, and moved the power window mirror, you would kill the car.
Old Oct 19, 2005 | 10:55 AM
Grumpy's Avatar
Grumpy
MONARTOR
From: What I know, is dwarfed by what I pretend to know
Cruise-In 5-6-7-8 Veteran
kasp
not really.. does it less..mine dims every day, while lights are on, approximately 5 minutes after I leave home, almost in the same spot. Can set yoyur watch to it..only does it one time.. used to do it a lot with the GM battery( turn signals, windows etc..)
Old Oct 19, 2005 | 10:56 AM
SGT. PYLE's Avatar
SGT. PYLE
kasp
Not true. I heard this and went out and bought a Red Top. Lights still dim when you hit the windows.
Old Oct 19, 2005 | 01:00 PM
Mine does the same. I'd say it is normal.
Old Oct 19, 2005 | 07:31 PM
vcarr's Avatar
vcarr
Experienced in auto electric. Normal.
Old Oct 20, 2005 | 12:55 AM
dataporter's Avatar
dataporter
Thanks everyone for responding!!!
To Headlights dim slightly with window roll up
