Trouble with lighting, PLEASE HELP
First the passenger side headlight grinds for about 6 seconds after turning my headlights off. I think I have that one solved because Im almost sure its the gear and Im going to get a brass one.
Secondly, the other day I turn my drivers side turn signal and notice its blinking reallly fast. I look at the reflection of my car in the car in front of me and realize my Drivers side DRL isnt on. Nor does the turn signal work in the front. However the drivers side turn signal still works in the back, its just blinking rapidly. Then to top it off when i got home and turned off my headlights, the drivers side headlight goes down and then pops back up about half way and I have to manually lower it back down now...
So I figured the front DRL/turn signal needed replacing so I went and bought a replacement bulb. Well, turns out the bulb that was in there wwas fine. It comes on when I turn my headlights on but when im driving it DOESNT come on as a DRL and it DOESNT come on as a turn signal. Yet it DOES come on when the headlights are on. What in the world is up with my drivers side light issues??? Im so frustrated with my c5 right now I'm second guessing buying it even though I love it.
For the time being I pulled the #2 fuse so both DRL's are off so that doesnt look so bad when im driving during the day. But I need to find out the turn signal and why the headlight pops halfway back up after turning them off.... ANYBODY have ANY clue on either issue?
As for your lights grinding, etc. .. sounds like your gear is going out. It's a nylon gear that wears out... replace it with a brass one and no more issues. A buddy of mine just replaced a set and he cracked the headlight motor open, replaced the gears and epoxied the motor back together.
Hang in there... I've gone through a load of crap dealing with mine as well... and I also contemplated jumping ship last year... but I'm glad I didn't. This is pretty minor stuff...
Hopefully, if you're not mechanically inclined, someone in your area can step up and lend you a hand.
Good luck
Dave Q.
Good luck
Dave Q.
It sounds as if you've got the headlight issue figured out. I'm 99% sure it is a gear going out on you. As to the bulb. I'm quite positive as well that it is a bulb issue, the fast blink of the turn signal is the give away. Remember, the dual filament is for the DRL, parking light/turn signal. Go ahead and replace the bulb.Paul
