collapse upper hose
Old Oct 19, 2005 | 08:19 PM
grunz95's Avatar
grunz95
Default collapse upper hose
Has anyone had this problem? I just bought a 99 coupe. When I was checking over the car I notice the upper radiator hose was collapse, just in the center. I took the car to the dealer and they told me to check the level of the anti-freeze. If it is low that could cause the problem because of the vaccum in the system. When the car is started the hose goes back to normal size.
Old Oct 19, 2005 | 08:44 PM
1993_FD3s's Avatar
1993_FD3s
yes you have air in the system and are low on coolant. when it is hot and you rev the engine it will collapse also. like on the freeway
Old Oct 19, 2005 | 09:43 PM
Evil-Twin's Avatar
Evil-Twin
St. Jude Donor '03-'04
You have a bad radiator cap..... it is not holding pressure...very common symptom, very simple solution.
Old Oct 20, 2005 | 09:56 AM
Good info to know.
Old Oct 21, 2005 | 04:59 PM
vettenovice's Avatar
vettenovice
I had the same problem. I had my system flushed (needed it) and the problem went away. Also, since I was getting the sysmte flushed, I had the hose replaced.
Old Oct 21, 2005 | 05:01 PM
c5BlackBeauty's Avatar
c5BlackBeauty
Lifetime Member
St. Jude Donor '05, '12-'13, '15-'16, '21
Intersting. I wouldn't think low coolant would have had that effect. Good to know.
Old Oct 21, 2005 | 08:15 PM
dpd's Avatar
dpd
evil-twin is right.the cap on the overflow jug is bad.
Old Oct 21, 2005 | 08:53 PM
GKrenn's Avatar
GKrenn
Does anyone have the P/N of the over flow cap?
Old Nov 5, 2005 | 10:21 PM
grunz95's Avatar
grunz95
Default Thanks for all the help
I check the level of the coolant its ok. How do I check the cap ? Also the car only has 34,000 miles on the car do I really need to have the system flushed? Does anybody know how to bleed the system to remove the air?
Thanks, Grunz
Old Nov 5, 2005 | 11:26 PM
GrayC5's Avatar
GrayC5
Your dealer should have a testor to test the cap to see if it is holding and releasing pressure as it should. But, with you car going on 6+ years old, it's most likely past time to replace the cap and as E-T mentioned, it's very likely the source of your problem. Too, it appears it may be past time to drain and flush the cooling system. The cooling system in your vehicle was filled at the factory with DEX-COOL® engine coolant. This coolant is designed to remain in your vehicle for 5 years or 150,000 miles, whichever occurs first, if you add only DEX-COOL® extended life coolant. The 2003 GM Service Manual says to use only GM Goodwrench® or Havoline® DEX-COOL®. You should find more info on this topic in of your owner's manual. Good luck.
Old Nov 6, 2005 | 03:10 PM
grunz95's Avatar
grunz95
Default Thanks
I will take the car to the dealer this week to check the cap and flush out the system.
Grunz
Old Nov 6, 2005 | 08:45 PM
RonJ's Avatar
RonJ
The cap vent isn't opening when the coolant cools down. This creates a low pressure in the system, and instead of drawing coolant back from the reservoir, it collapses the upper hose.
Sometimes cleaning the cap with a good strong stream of water will help. On a conventioanl rad cap, you can check the vent valve with your finger nail, not sure about the screw on cap the C5 uses.
RonJ ...
Old Nov 6, 2005 | 09:00 PM
Poptops's Avatar
Poptops
RonJ ...
Try this before going to the stealership.
To collapse upper hose
