Fix-a-Flat
Old Oct 21, 2005 | 03:40 PM
YellowPowerC5's Avatar
YellowPowerC5
Default Fix-a-Flat
just out of curiosity.
Will fix-a-flat or other like products hurt the tire sensors in our cars?
YP
Old Oct 21, 2005 | 03:44 PM
HERK's Avatar
HERK
yes
Chicago's Avatar
Chicago
St. Jude Donor '15
Yes, Fix-a-Flat will kill the sensors.
Old Oct 21, 2005 | 03:50 PM
Shylor's Avatar
Shylor
If you have run flats, why would you use fix-a-flat?
Old Oct 21, 2005 | 04:02 PM
YellowPowerC5
I dont have run flats on the car
Old Oct 21, 2005 | 04:08 PM
Shylor's Avatar
Shylor
Then just use fix-a-flat in a can in an emergency if a vulcanizing plug kit and small jack don't work.
Old Oct 21, 2005 | 04:16 PM
diyguy's Avatar
diyguy
I see no reason why you could not use that stuff to get you somewhere off the road and into a town or a tire shop..
Just make sure the inside of the tire and wheel are cleaned up with soap and water and get it patched properly.
I seriously doubt it would ruin tire sensors in the span of 24 hours or so, if that.
Old Oct 21, 2005 | 04:37 PM
c5BlackBeauty's Avatar
c5BlackBeauty
Lifetime Member
St. Jude Donor '05, '12-'13, '15-'16, '21
Old Oct 21, 2005 | 04:54 PM
Cheech Wizard's Avatar
Cheech Wizard
This product is supposed to be tire sensor friendly:
http://www.tirerack.com/accessories/...tkit/index.jsp
Old Oct 21, 2005 | 04:57 PM
blacksedan87's Avatar
blacksedan87
St. Jude 15 Year Donor
From: "It's 106 miles to Chicago, we've got a full tank of gas, half a pack of cigarettes, it's dark, and
St. Jude Donor '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17-‘18-'19
If you don't have run flats (extended mobility tires), then you should be carrying either a plug kit and compressor or your "towing" card. If you chose only the later - be prepared to stand around waiting for the flatbed. But whatever you do - understand that if you should choose to use the goop in a can, you're going to wind up replacing the sensor in that wheel.....
Old Oct 21, 2005 | 05:56 PM
Y2Kvert4me's Avatar
Y2Kvert4me
CI 6-7-8-9-10 Veteran
St. Jude Donor '03
Have you tried it?
Just curious. I know of 3 people that have used it, and none of them had a sensor go bad because of it.
In 3 years on this forum, I've not read of anyone that actually had the sensor die because of it. Guess that makes me a skeptic, but I think this is more internet rumor than reality.
I'm sure it could plug a sensor and render it useless, but I just can't find anyone that that's actually happened to.
I keep a can in the car, as well as a plug kit and compressor.
Old Oct 21, 2005 | 07:19 PM
MyVetteDream's Avatar
MyVetteDream
From: HOW FAST WAS I GOING OFFICER? Los Angeles Hating GM Dealership Service Dept.'s Since Sept. 2004
St. Jude Donor '04-'05-'06-'07
Someone was just telling me about a "dry" fix-a-flat... I'll have to do some checking around and get back to you guys.
Old Oct 21, 2005 | 08:18 PM
RonJ's Avatar
RonJ
Originally Posted by blacksedan87
If you don't have run flats (extended mobility tires), then you should be carrying either a plug kit and compressor or your "towing" card. If you chose only the later - be prepared to stand around waiting for the flatbed. .....
RonJ ...
Old Oct 21, 2005 | 08:58 PM
MyOwn69's Avatar
MyOwn69
Originally Posted by Y2Kvert4me
Have you tried it?
Hmmmmm.........
Could we be dealing with an urban legend?
Step up - who's had one ruined by the stuff?
(this COULD be BIG!!! )
Old Oct 21, 2005 | 09:06 PM
C5naples's Avatar
C5naples
I have seen that kit for $75. Supposedly the goo that repairs and fills the tire is water based and can be peeled of the sensor when you take the and tire in to be repaired.
Old Oct 21, 2005 | 09:37 PM
SLPRC5's Avatar
SLPRC5
Damn good advice
SLPRC5's Avatar
SLPRC5
If you have too, this is the way to go
To Fix-a-Flat
Old Oct 22, 2005 | 12:18 AM
12stepvette's Avatar
12stepvette
I used to help run a custom Bike shop...We sold some very expensive wheels, mostly chromed or brushed aluminum. One of our customers used fix-a-flat on a long ride, 2 weeks I think. The wheel was broken down for replacement, and it was already starting to corrode from the fix-a-flat!!! I personally will never use the stuff after seeing that. A plug kit and compressor is the only way to go.
Old Oct 22, 2005 | 01:09 AM
M_T_0's Avatar
M_T_0
Originally Posted by MyOwn69
Hmmmmm.........
me!
Old Oct 22, 2005 | 01:53 AM
Shylor's Avatar
Shylor
Funny I've heard many forum members have ruined their sensors by using the stuff. I wonder if they just didn't clean the sensors properly afterwards. I have never done it so can't comment from experience.
