Steering/airbag ?
Old Oct 22, 2005 | 11:22 AM
jmzvet's Avatar
jmzvet
Default Steering/airbag ?
I had my airbag replaced at the dealer and now my steering wheel seems to be slightly off center. Does the wheel have to removed to replace the airbag?
Old Oct 22, 2005 | 11:31 AM
CCA Corvette Parts's Avatar
CCA Corvette Parts
Premium Supporting Vendor
St. Jude Donor '07-'08,-'13-'14, '16-'17
No, but the airbag has to be removed to replace the steering wheel...
Peace
Willfulone
__________________
..................Click for
Old Oct 22, 2005 | 11:33 AM
jmzvet's Avatar
jmzvet
Strange that it seems to be off center .
Old Oct 22, 2005 | 03:49 PM
Lancer033's Avatar
Lancer033
did you get an alignment done recently?
If so, your front toe could be off off. Total toe could be right, but individual toe on each wheel could be a little off.
Old Oct 22, 2005 | 05:22 PM
Der Flieger's Avatar
Der Flieger
Default Airbag replacement
The shop manual requires replacement of the clockspring if it shows damage from airbag deployment, and that requires steering wheel removal. If they did not mark the steering wheel hub before removal, they perchance they got it "off" by one tooth. Did the repair invoice show replacement of the clockspring?
Old Oct 22, 2005 | 05:25 PM
edensknight's Avatar
edensknight
Take the car back to the dealership to service this issue.
Old Oct 22, 2005 | 08:19 PM
jmzvet's Avatar
jmzvet
The airbag did not deploy. The red airbag light has been lit on the ip for a while so they replaced the airbag module under warranty ($900!).
I will be taking it back. It's annoying .
Old Oct 22, 2005 | 08:21 PM
jmzvet's Avatar
jmzvet
It was dead on (steering wheel center) when I left it at the shop.
Old Oct 22, 2005 | 09:08 PM
WNeal's Avatar
WNeal
Cruise-In Veteran VII
Cruise-In Veteran VIII
"Slower Azz Dog"
St. Jude Donor '06-'07-'08-'09
Definitely a trip back to the dealer.
Tell em you need it fixed right.
If it is off center, it will bug you from now to always.
Its not something you can forget about either since you deal with it every time you drive
Old Oct 24, 2005 | 03:28 PM
Der Flieger
Default Airbag module replacement
If they only replaced the airbag control module, then they did not have to remove the steering wheel, just the center console and the HVAC control to get to it. However,some of the the stories I have read on the Forum leads me to believe that not every dealer has a well-trained "Corvette Guy" in his shop, and consequently some "fumbling around" happens, and things are torn apart for no good reason, and not put back together correctly. Heck, maybe they hit a curb during the 'test drive'?
Old Oct 24, 2005 | 05:52 PM
jmzvet's Avatar
jmzvet
I spoke to the service writer today and he told me they did remove the entire steering wheel. They obviously re-installed it a bit off. I will be taking it back on Wednesday .
To Steering/airbag ?
