Glovebox removal!
Old Oct 22, 2005 | 04:44 PM
IDM's Avatar
IDM
Default Glovebox removal!
Hey team,
I'm having a hard time figuring out how to remove the glovebox.
I got down with my back on the floormat and see 2 screws up there. Is that how it comes off? Now my question is HOW would I ever get those back in if they are the right ones? I see a way to get them out but there's no way I could get them back in there unless something else comes off as well.
Pics always welcome!!
Thanks in advance
Old Oct 22, 2005 | 05:07 PM
JeepTJ's Avatar
JeepTJ
St. Jude Donor '05-'06-'07-'08-'09-'10-'11
Remove the glove box by removing the 7mm screws located @ the top of the glove box when opened. Take a flat headed screw driver and pop the big plastic plugs. Covers off the inside of the glove box. You will now see 2, 10mm bolts. Use a 10mm swivel socket to remove these and pull the glove box away.
And yes, these are fun to put back-in.
Old Oct 22, 2005 | 05:17 PM
IDM's Avatar
IDM
I just got it out! Thanks
This is the thread I found
http://forums.corvetteforum.com/show...box&forum_id=1
I'd like to add my removal procedure:
there are 4 7mm bolts up top. The I removed the 1 7mm bolt on the side piece that meets with the door (because I want this piece out too). After that push from behind one the 2 big plugs on the inside of the glovebox and at the same time get a tiny flathead under the part you're pushing up against and they come right out. Now you can see the 2 10mm bolts and remove them and you're done.
Thanks everyone! This is too much fun ohhh yeah!
To Glovebox removal!
