need some help
Old Oct 23, 2005 | 11:34 AM
idontknow's Avatar
idontknow
Default need some help
i am really interested a corvette that is really a steal for everything it has. here is the claim history, has a clean carfax. would you be concerened about the car with all this being shown or would you just think it is an **** corvette owner.
CLAIM HISTORY
R.O Date R.O Number Type Labor Operation Odometer Reading
04/26/2005 374094 # V1145 - 04006 - PERFORM REPROGRAM AND FUNCTIONAL TEST - MANUALS ON 35200 miles
04/30/2003 319794 # J6360 - MODULE, PCM/VCM - REPLACE 29649 miles
04/30/2003 319794 # Z7901 - 1-DAY COURTESY TRANSPORTATION 29649 miles
04/30/2003 319794 # Z5001 - VIP FREIGHT/POSTAGE REIMBURESEMENT 29649 miles
08/27/2002 301386 # L1200 - SENDER AND/OR PUMP ASSEMBLY, FUEL (TANK UNIT) - REPLACE 26606 miles
08/27/2002 301386 # F2005 - COVER AND/OR GASKET, DIFFERENTIAL - REAR DIFFERENTIAL - LE 26606 miles
08/27/2002 301386 # Z7902 - 2-DAY COURTESY TRANSPORTATION 26606 miles
07/18/2002 298350 # L1200 - SENDER AND/OR PUMP ASSEMBLY, FUEL (TANK UNIT) - REPLACE 25878 miles
07/18/2002 298350 # F2005 - COVER AND/OR GASKET, DIFFERENTIAL - REAR DIFFERENTIAL - LE 25878 miles
07/18/2002 298350 # Z7903 - 3-DAY COURTESY TRANSPORTATION 25878 miles
04/23/2002 292166 # C2007 - MOLDING, WINDSHIELD GARNISH - COMPLETE - R&R OR REPLACE 22600 miles
04/23/2002 292166 # Z7901 - 1-DAY COURTESY TRANSPORTATION 22600 miles
09/11/2001 276142 # V0743 - ECL RELAY HARNESS REPLACE 18354 miles
03/06/2001 262239 # C9040 - BELT, SEATBELT RETRACTOR (FRONT) (RIGHT) - REPLACE 11193 miles
03/06/2001 262239 F Z7200 - CORPORATE PARTS RETURN REIMBURSEMENT 11193 miles
11/29/2000 255665 # V0505 - INSPECT LAP BELT RETRACTORS,INSTALL WEBBING GUIDES 10688 miles
11/29/2000 255665 # N3215 - ACTUATOR ASSEMBLY - DOOR LOCK - LEFT FRONT - REPLACE 10688 miles
11/16/2000 254769 # J0101 - MANIFOLD, EXHAUST - LEFT BANK - REPLACE 10608 miles
11/16/2000 254769 # N3215 - ACTUATOR ASSEMBLY - DOOR LOCK - LEFT FRONT - REPLACE 10608 miles
10/11/2000 252183 # C0040 - MIRROR, INSIDE REAR VIEW - REPLACE 9918 miles
10/11/2000 252183 # N3215 - ACTUATOR ASSEMBLY - DOOR LOCK - LEFT FRONT - REPLACE 9918 miles
07/13/2000 245767 # K9992 - CUSTOMER CONCERN NOT DUPLICATED 7709 miles
04/10/2000 239377 # C0182 - REGULATOR, FRONT DOOR WINDOW - RIGHT POWER - R&R OR REPLAC 3531 miles
01/19/2000 234413 # J9991 - CUSTOMER CONCERN NOT DUPLICATED 2164 miles
01/07/2000 233698 # E0721 - SENSOR, LOW TIRE PRESSURE WARNING - FRONT - LEFT - REPLACE 1976 miles
08/27/1999 225664 # Z6999 - PDI RELATED FLUID ADDS 14 miles
08/24/1999 503585 I Z7000 - PRE-DELIVERY INSPECTION - BASE TIME 0 miles
Old Oct 23, 2005 | 11:39 AM
vetteshop's Avatar
0vetteshop
Former Vendor
St. Jude Donor '13
Though that list may look alarming,it is not out of the ordinary.Most of the repairs listed are common C5 faults.I would have someone put the vehicle on a lift and go over the car before a purchase
Old Oct 23, 2005 | 11:48 AM
idontknow's Avatar
idontknow
i was just concerened about it. i am going to look at the car today and go over it with a fine tooth comb. it is a 2000 with 41k for 22k and is fully loaded with everything.
Old Oct 23, 2005 | 04:37 PM
Reading through that list, its not bad. Many of those things are very common problems so don't be all that alarmed.
Old Oct 23, 2005 | 04:53 PM
talon90's Avatar
talon90
Cruise-In 11 Veteran
NCM Ambassador
St. Jude Donor '05-'06-'07-'10
Good luck with the look see. Let us know how it turned out.
Paul
Old Oct 23, 2005 | 05:06 PM
idontknow's Avatar
idontknow
well i went over it today with a fine tooth comb and didn't find anything wrong with it. everything checked out with the car, has a clean carfax. it is a 2000 bowlingreen metallic with 41k miles. ti has a borla exhuast, BMR shifter, C5r lights, fully loaded with every option and has both roofs. getting it for a steal price 21,500
To need some help
