DIC (Dashboard) Light Replacement
Old Oct 23, 2005 | 08:51 PM
humvet's Avatar
humvet
Default DIC (Dashboard) Light Replacement
The top three DIC buttons don't light up on my 99 when I turn on the dashboard.
I assume that a lamp is out - what is the best approach to replace it?
Do I come from underneath, take out the cluster, etc? I don't want to dismantel the entire dash to find out that there ia a straight forward aproachl
Old Oct 23, 2005 | 09:24 PM
vetteshop's Avatar
0vetteshop
Former Vendor
St. Jude Donor '13
You have to remove the cluster Order the bulb 1st before you take it apart.It is an odd little blue bulb that you will more than likely have to order...
