[Z06] how much hp to pull 6th gear,
Old Oct 25, 2005 | 02:28 PM
slow99's Avatar
slow99
Default how much hp to pull 6th gear,
stock gearing, c5 z06. every post i've seen regarding top speed has to do with changing 5th gear rev limit etc...so how much hp would it take to pull mph our of 6th gear? thanks!
Old Oct 25, 2005 | 02:31 PM
Turbooo2u's Avatar
Turbooo2u
Pull to what speed? Near redline would require an awful lot. Probably in the order of 1000hp.
Old Oct 25, 2005 | 02:36 PM
slow99's Avatar
slow99
any , if it's 180 ish at 6500 rpm in 5th, then let's just say to put it in 6th and hit 195 or so.
Old Oct 25, 2005 | 03:33 PM
zeevette's Avatar
zeevette
A stock '02 Z will hit 174-5 in 5th. Shift to 6th and you slow down. Don't ask me how I know. I think with stock 3.42's, it's geared to go about 250 @ redline in 6th. To acheive that would take more than 1000 hp IMHO. Air resistance/ drag is exponential, and requires bigger HPgains to make smaller top speed increases, as overall speed is raised.
Old Oct 25, 2005 | 05:11 PM
Vettez16's Avatar
Vettez16
? is that with the rev limiter raised in 5th or factory setting.
Old Oct 25, 2005 | 07:00 PM
zeevette's Avatar
zeevette
That's stock @ around 6800. 174-5, that is.
Old Oct 25, 2005 | 07:06 PM
_Rudy_'s Avatar
_Rudy_
man, ....Ive been told theres only enough straightaway for 150 or so around here....
Old Oct 25, 2005 | 08:21 PM
SVTMADMAN's Avatar
SVTMADMAN
Ive asked myself the same question, but ive got a 3.73 under mine it it feels pretty good in "High Range"
Old Oct 25, 2005 | 08:51 PM
Znod's Avatar
Znod
Here's a link to a top-end related thread that should add to this discussion. Maybe someone would like to resurrect it. It seemed to die a premature death.
Old Oct 25, 2005 | 08:57 PM
#001 2001 Z06's Avatar
#001 2001 Z06
NCM, WSCC & SCC Member
About 500, will get you to 190 mph.
750 about 220.
If you are not pro driver or have at least fifteen years racing under you belt and perfectly setup car, I would highly recommend not attempting it.
Stock, at about 145 mph, these cars tend to lift and at 190 the tail will lift.
Old Oct 25, 2005 | 09:08 PM
Znod's Avatar
Znod
750 about 220.
Interesting. You convinced me. I'm no longer thinking of trying it. ~{;^) I do wonder why GM didn't govern the car if it is that potentially dangerous to us amateurs at 145+. My 94 RX-7 felt rock-solid at 145+.
Old Oct 25, 2005 | 09:22 PM
Dr.Ron's Avatar
Dr.Ron
From: 2007 Nat'l Corvette Challenge 11.50 index Champ. New Jersey
750 about 220.
I hit that (145) at Pocono on the back straight away & my car felt like it was doing 70mph....
Ron
Old Oct 25, 2005 | 10:12 PM
ksett's Avatar
ksett
750 about 220.
I've gone 152 mph and the car felt very stable. I've also never heard of anyone claiming the car felt unstable at speeds over 160 mph.
#001 2001 Z06
Ron
A roadcourse is much different than a highway. *Generally, a controlled smooth environment. *subject to various varibles. Also, there is generally notice(yellow/red/black/yellow) if there is problem ahead. Tires are also much hotter and stickier.
Highways have all kinds of issues.
Many more occillations. Various debrie; oil, dirt, moisture, etc. Traffic at substantially different speeds, which could result in major changes in momentum. etc.,etc.
EG. I would have zero problem going down Sebring or on the Autobahn at 200+ mph. in the right conditions.
On the highways here, I always use judgement. 120-180 max. depending on conditions.
I did 180 a few days ago. I have a full custom C5R type suspension.
Old Oct 25, 2005 | 10:32 PM
Znod's Avatar
Znod
Stock, at about 145 mph, these cars tend to lift ....
Did you mean on a smooth straight road with no traffic?
Old Oct 25, 2005 | 10:50 PM
Pumba's Avatar
Pumba
I have had my Z06 at 180+, and it was still accelerating, when I had to slow for traffic up ahead. It was completely stable at that speed and the brakes pulled it down to 75 quickly and in a straight line.
Old Oct 25, 2005 | 10:56 PM
Znod's Avatar
Znod
Beautiful car. it looks a great deal like my black 02. ~{;^) I have forgotten who makes/sells the spoiler. After all this time, I am thinking maybe I need one.
To how much hp to pull 6th gear,
Old Oct 25, 2005 | 11:14 PM
#001 2001 Z06
If you hit and occilations in the road car will you catch air. Less weight on the tires. This is not a problem if you going straight at 145.
When have to change direction/momentum (turn) at speed, then you have worry about keeping max adhesion at 145.
I would not do a spoiler without addtional downforce on the nose (air dam, conards, hood). All you are going to do push down the back and create lift on the front.
Most of spoilers/ground effects sold here are junk.
1) Only use ones that have been wind tunnel tested.
2) tested at speed
3) Used at the track.
http://photobucket.com/albums/b208/B...cane%20Relief/
I do four wheel skids at 90-120+ mph when I am feeling perfect, very motivated and conditions are right.
Pumba, above is running conards and good 37 degree spoiler. Plus it look as though he is lowered to T-1 height(1.5").
Old Oct 26, 2005 | 12:18 AM
master blaster's Avatar
master blaster
i went 198 with the vert top down.....still had more in her!
Old Oct 26, 2005 | 12:44 AM
Chris Stewart's Avatar
Chris Stewart
I ran these numbers thru a math simulation program using the Z06 specs, take it for what it's worth.
405hp ~175mph in 5th
450hp ~186mph in 6th
500hp ~197mph in 6th
550hp ~205mph in 6th
600hp ~212mph in 6th
650hp ~219mph in 6th
700hp ~224mph in 6th
750hp ~229mph in 6th
800hp ~234mph in 6th
850hp ~239mph in 6th
900hp ~243mph in 6th
950hp ~247mph in 6th
1000hp ~251mph in 6th
