Corvette Wheel Question
Old Oct 27, 2005 | 03:22 AM
C5Generl's Avatar
C5Generl
Default Corvette Wheel Question
will Z06 wheels work on a C5 with out tire pressure sensors? will this affect active handling or anything? can i run wheels on a c5 without tire pressure sensors or are the tire pressure sensors mandatory?
Old Oct 27, 2005 | 03:26 AM
mph1972's Avatar
mph1972
Cruise-In VIII Veteran
St. Jude Donor '07
I say yes, you are just going to have that DIC reminder pop up every time you get in the car and no, it will not affect handling, or any of that stuff.
Old Oct 27, 2005 | 04:17 AM
C5Generl's Avatar
C5Generl
after i start up the car will the reminder pop up.. and then go away?
or will it just stay on?
Old Oct 27, 2005 | 05:03 AM
VA 98 VETTE's Avatar
VA 98 VETTE
You will need to push the reset button each time.
Old Oct 27, 2005 | 06:40 AM
talon90's Avatar
talon90
Cruise-In 11 Veteran
NCM Ambassador
St. Jude Donor '05-'06-'07-'10
The wheels will work without the sensor. I have to ask, why wouldn't you want the sensors? The piece of mind is well worth it, especially with non-runflat's. Wouldn't you want to be warned ahead of time of a possible problem at speed? You don't list what year your car is (drives us all crazy b.t.w.) so we can't answer your upcoming question as to weather or not it can be disabled. You will have to press the reset each time you start the car to clear the warning.
Old Oct 27, 2005 | 06:55 AM
But, I too would recommend using the sensors. Sure is nice to know if your tire is losing air.
Old Oct 27, 2005 | 06:57 AM
cenzo's Avatar
cenzo
My tire/wheel guy couldn't make my '99 sensors fit the GM Z06 wheels because they are not spot-faced on the back of the valve stem hole. The radiused mounting surface prevented a good O-ring seal.
To Corvette Wheel Question
