Power antenna replacement
Old Oct 27, 2005 | 12:09 PM
samricky's Avatar
samricky
Default Power antenna replacement
How do you access the assembly to replace this part? I assume that it is through the trunk or wheel well. Is it possible for someone with a service guide to post the instructions on this? Thanks in advance.
Old Oct 27, 2005 | 12:24 PM
PHVette's Avatar
PHVette
St. Jude Donor '06
Default Antenna Change out
I have a 99 Vert. I removed thru the tail light assembly. Wiring connections were in the trunk behind the wheel well carpet on passenger side.
