i need to buy a new middle compartment cover for the trunk. i have the part # 10313594. i need a new one because i installed a sub box in the compartment and the sub sits a little to high for the cover to go over it without touching it so id like to buy another one to cut a hole in to allow the sub to come up thru. i have a shale interior (ae vert) and was wondering if this comes carpeted with shale carpet? could somone check thiers (of a different color) to see if the part # is different. gm parts direct has them for 69.00 but id like it carpeted since its impossible to get shale carpet. thanx brad
As food for thought, you might give ole Gene at the Karshop a call. Gene may very well have a low cost used middle compartment cargo door for you, and, save you some cash.
If you got that based on your year or VIN from the dealer you should be good to go. The parts list I have (only good to 2002) breaks out each compartment by color. There is a different part number for black, gray and red as listed in my catalog. If someone has a more current parts list they will be able to confirm for you.
Paul
There should be a different part number for each color.
