Jacking Pucks Just Making Sure
Old Oct 29, 2005 | 01:08 PM
DRJJ1's Avatar
DRJJ1
Default Jacking Pucks Just Making Sure
Is There A Way To Bang These Lifting Pucks I Got From Bmw Into The Holes Under The Car Without Lifting The Car Up To Slam Them In....views Please
Old Oct 29, 2005 | 02:24 PM
rws.1's Avatar
rws.1
They are supposed to slip right into the slots in the frame.... so banging should be required. If you have the right pucks and the right location it is easy to push them into place and then twist 90 degrees to lock in place. Should be easily done with the car on the ground
Old Oct 29, 2005 | 02:35 PM
Bakersfield's Avatar
Bakersfield
I made a set of 4 myself for about $20 bucks. Out here in sunny SoCal, we don't get a price break on hocky pucks but you may do better. Good luck.
Old Oct 29, 2005 | 03:17 PM
MTCorvette's Avatar
MTCorvette
I bought my hockey pucks from Play It Again Sports for a buck and a half each. I got the heavier orange ones. Then stopped by Lowes for 1/4" eye bolts at about 33 cents each. Drill a hole in the center, screw in the eye bolts, and they fit right in the slots. Twist 'em about 90 degrees and they stay while you place the jack.
Old Oct 29, 2005 | 04:17 PM
BobbyG's Avatar
BobbyG
St. Jude Donor '06-'07
Will these home-made pucks support the cars weight over a 6 month winter storage? My jack-stands are certainly sturdy enough but I didnt know if the pucks themselves would stand up to this.
Your comments are always appreciated!
Bob
Old Oct 29, 2005 | 04:23 PM
turbosupra18's Avatar
turbosupra18
Bob
I think the hockey pucks will be just fine for the winter. I'm looking into buying either the Elite Engineering or bmw jackpucks. You can leave the bmw pucks in, so I'm leaning towards those.
Old Oct 29, 2005 | 05:17 PM
Floridasky's Avatar
Floridasky
St. Jude Donor '15
I bought a set but made the box to store them in. Fits perfect in the rear side compartment.
Old Oct 29, 2005 | 05:28 PM
MY1STPEWTER's Avatar
MY1STPEWTER
Fancy looking setup there.
Old Oct 29, 2005 | 05:37 PM
Cajun99's Avatar
Cajun99
If you're banging or slamming ANYTHING on your Vette then there's either a problem with your technique or you're just simply not doing it correctly.
Old Oct 29, 2005 | 08:20 PM
WALLstAL's Avatar
WALLstAL
St. Jude Donor '05
At the Sports Chalet they were $1!
Old Oct 29, 2005 | 11:00 PM
DRJJ1's Avatar
DRJJ1
Default Pucks
They Seem To Fit But Only If I Bang Them In Lightly,,,there Are 2 Prongs That Will Catch In The Hole After I Push Them In Hard Or Tap Them In With A Mallet,,,these Are The Only 2 Holes I See On One Side Of The Car,,,i Can Maybe Get 2-3 Finger Into The Hole The Pucks Will Hold Once I Get Them Into The Hole I Just Dont Want To Damage The Car Holes/pucks,,
Old Oct 30, 2005 | 05:54 AM
Cajun99's Avatar
Cajun99
There are two slots on either side of the car. You just slip the pucks into the slots with the prongs facing front to rear and slide them back. Turn them 90deg and they're in. Shouldn't even be a tight fit.
Old Oct 30, 2005 | 06:18 AM
sailohio's Avatar
sailohio
I didn't know the pucks were so complicated.
Old Oct 30, 2005 | 07:16 AM
C32B's Avatar
C32B
Default What the Puck?!?
Seriously!
$39.95 shipped to your door from Elite Engineering
http://www.eliteengineeringusa.com/jacking-pads.html
Old Oct 30, 2005 | 05:32 PM
DRJJ1's Avatar
DRJJ1
Default lol ok got it
man, I tried today with more time and I finally got them snapped into place but let me tell you all, it was not as easy as I thought it would be,,seems simple but I bought the bmw pucks and you have to play with them a bit until they snap into the hole,,but when they do snap in they pop in nice and firm...thanks for the info and support, you just want to make sure you re not going to break anything,, so it doesn t hurt to ask...so the bmw ones fit nice in case anyone is thinking about buying them,,they also are a very hard plastic so 2 pucks are not needed..
Old Nov 2, 2005 | 04:30 PM
DRJJ1's Avatar
DRJJ1
Default Pucks Done Next Project
Ok Im Done With The Pucks And They Are Snapped In Nice,,,now For The Front End Saver Wheels ,,,,
Old Nov 2, 2005 | 04:47 PM
BlueL36's Avatar
BlueL36
Cruise-In V Veteran
Cruise-In VI Veteran
plain ol' hockey pucks between the frame and a 3-ton jack work just fine.
To Jacking Pucks Just Making Sure
Old Nov 2, 2005 | 05:06 PM
Humanoid 2.0's Avatar
Humanoid 2.0
St. Jude 15 Year Donor
Cruise-In VII Veteran
St. Jude Donor '05 thru '19
I have the bmw pucks and I was able to push them in with my he-man strength, no mallet required.
Old Nov 2, 2005 | 05:56 PM
mitch.smith's Avatar
mitch.smith
Bought the pucks from elite eng. $39.95 + FREE Fedex Ground
Old Nov 2, 2005 | 06:36 PM
bennettrp's Avatar
bennettrp
St. Jude Donor '06-'07-'08-'09-'10,'13-'14,'19-'20-'21-'22
Pucks at $1 each.
