Rust/Pitting on Frame
Old Oct 29, 2005 | 04:48 PM
Joevette99's Avatar
Joevette99
Default Rust/Pitting on Frame
I was replacing my sway bar on the rear of the car and I noticed salt like deposits and pitting of the frame above the mufflers. Seems to be across the entire width of the frame. I plan to clean it and paint but was wondering if this is a common problem caused by water spray from the tires. I do not live near the beach but do drive in winter so I guess it from the salt on the ground left over after a snow storm.
Thanks.
Old Oct 29, 2005 | 05:20 PM
LoneStarFRC's Avatar
LoneStarFRC
Thanks.
Sounds like salt/chemical problem to me too. I would recommend cleaning, light sanding and painting, possibly with epoxy paint. If you're getting this corrosion showing up on the frame, you need to keep a close eye out on your electrical ground connections too. They can give you fits with electrical gremlins if you don't.
Do a search on posts by Bill Curlee. He be da' man when it comes to preventative measures involving this stuff. HTH
Old Oct 29, 2005 | 05:49 PM
Joevette99's Avatar
Joevette99
Thanks I appreciate the advise......
Old Oct 29, 2005 | 08:06 PM
edensknight's Avatar
edensknight
Good advice.
To Rust/Pitting on Frame
