I have a 04 vert that I can never get the deck lid open unless I shut the door after hitting the release button. I have already had the dealer replace the activator but didn’t help.
Can any direct me to any old threads on the subject?
If you mean that the lid is to low and you cant get a finger under it after you pop it , then lube all moving parts latches , hinges ect. with some gun oil , 3 in 1, ect. In a pinch you can also use wd40 but that lube will not last long.Then on either side of the lid there are small rubber bump stops adjust them a bit out ,a quarter turn at a time and check each side of the lid closed so as to not make it too high from the body .
Yours being an '04, I would think it would still be under warranty. If so, I'd suggest taking it to your dealer to have it looked at and fixed. Good luck.
Or you could move to Florida where it stays warmer all year, that way it won't be a problem. Mine always pops right up unless it's cold out! btw, nice pic!
