Side Moldings
Old Oct 31, 2005 | 08:51 PM
MassaRusty's Avatar
MassaRusty
Default Side Moldings
I am about to buy a 99 torch red hardtop with 98,000 miles that has BSMs. I would like to take them off, but I was wondering if others had any problems when they did it. I have not seen the car in person yet, but the paint appears to be in very good condition. Is torch red a color prone to looking bad once BSMs are removed?
If you recommend taking them off, is a blow drier and fishing line the best way to get them off. I would really prefer to take them off, but I don't want the car to have a stripe in place of the BSMs.
Old Nov 1, 2005 | 01:04 AM
lpabsolute's Avatar
lpabsolute
Why take them off? Personally i think they look naked with outh the BSM. Either way, be careful.
Old Nov 1, 2005 | 02:39 AM
Z18Corvette's Avatar
Z18Corvette
If you take them of the collor differance will show , leav 'em on
Old Nov 1, 2005 | 12:56 PM
Chances are you will notice a difference in the paint color when you remove the BSMs. If it were me, I'd just leave them on the car.
Old Nov 1, 2005 | 02:02 PM
KMeloney's Avatar
KMeloney
I just took the BSMs off my '01 MY Z this summer. Yes, there was a "shadow" where the BSMs were -- but NO, it was NOT PERMANENT.
After some good washings, polishings, and time in direct sunlight, all signs that there were ever BSMs there disappeared completely. (Go ahead and read that again if you're not sure what you just read. )
It WILL take a little bit of time (especially now that the sun is a little less potent, at least here in PA)... But any lines should go away completely.
If you'd like to be sure, make sure you get responses from folks who 1) have a torch red car of a similar age, and 2) have ACTUALLY REMOVED THEIR'S. I know I've read that folks with TR cars have had the same experience as me.
If you'd like another shove in the direction of doing this, consider this: If the shadows DON'T disappear with some time, then you'll have a guide as to exactly where they ought to go back on the car.
Good luck!
-Kirk
Old Nov 1, 2005 | 02:13 PM
KMeloney's Avatar
KMeloney
If you recommend taking them off, is a blow drier and fishing line the best way to get them off. I would really prefer to take them off, but I don't want the car to have a stripe in place of the BSMs. Thanks
Forgot to address this...
I see now that you're in FLA. That's good -- 'cause I did this when it was cool in my garage, and that sure didn't help any. You want it to be warm out so that the adhesive doesn't fight you the whole way.
Now, I didn't use a hairdryer (again, too cool to make a difference), but that probably wouldn't hurt. Being in FLA, you shouldn't really need one, but it may help. I don't even know if it's possible, but just don't keep it in one area too long where it could "burn" the paint.
As for the fishing line, yes, this is the way to go. But use STRONG fishing line! The line that I used kept breaking, and it was frustrating to say the least. So, get sme really strong stuff.
Also, rather than wrapping the fishing line around your fingers (like you would use dental floss), consider making two "handles" that you can wrap the ends around so that they can take the cutting of the line, not your fingers.
I used an up-and-down sawing motion with the line as I pulled toward the rear of the car, guiding the line down the BSM. Be sure that you don't pull AWAY from the door too much, as you might find yourself digging into the back of the BSM instead of just the adhesive, making the job a LOT tougher (and damaging the BSM).
This job took some patience... But you'll love the results! For me, since I had the BSMs on the car for so long, it was like getting a new car. The difference is that dramatic.
-Kirk
matt24's Avatar
matt24
Took mine off last month (02) after a polish and wax i couldnt tell the difference, great mod !
Old Nov 1, 2005 | 06:28 PM
MassaRusty's Avatar
MassaRusty
Thanks for all the responses.
I think I will go ahead and try to take them off. I figure the worst case scenario is that I will have to get them put back on.
Old Nov 1, 2005 | 06:38 PM
MYRagtop's Avatar
MYRagtop
You can always put them back on if you have any issues.
Give it a shot.
Old Nov 1, 2005 | 08:36 PM
dooscoop32's Avatar
dooscoop32
[QUOTE=lpabsolute Personally i think they look naked with outh the BSM. [/QUOTE]
I love naked!
CRVETTE
Old Nov 1, 2005 | 09:32 PM
dabsgm's Avatar
dabsgm
1st Gear
undefined
how much did you purchase your vette for?
Old Nov 1, 2005 | 09:39 PM
Evil-Twin's Avatar
Evil-Twin
St. Jude Donor '03-'04
Torch red can be effected by UV rays... more so than other colors... ask any body shop, and they will tell you that red colors can be more expensive than other colors.. the car is six years old... chances are there will be a difference.. but as you say if it is too much, you can always put them back on...
Old Nov 1, 2005 | 11:13 PM
b98's Avatar
b98
same here looks good.
Old Nov 2, 2005 | 01:54 AM
FiberglassFan's Avatar
FiberglassFan
[QUOTE=dooscoop32]
Originally Posted by lpabsolute Personally i think they look naked with outh the BSM. :thumbs:[/QUOTE
I love naked!
CRVETTE
If this what naked be, I LIKE NAKED!
I do not like the BSMs at all, and totally approve of your choice to remove them. The original C5 designers did not include any form of BSM...They were not part of the original design studies, nor of the final production design.
To Side Moldings
