Repro wheels
Bruce
I have used them a few time, and have had very good luck with them. A buddy of mine got these remans for $208 each.
However, do keep in mind that not all enthusiasts are dedicated racers. Thus, these one piece cast aluminum repro-wheels are an attractive, and, low cost alternative and value for any auto enthusiast. And, allow more mass consumer appeal, wheel variety, and, options for the common consumer to enjoy.
Over time, the development of more improved low pressure, high pressure gravity alloy mold techniques for one piece cast aluminum wheels, have evolved since the advent of the eighties. But, forging metalurgy will remain as a top tier quality product with virtually none of the porosity that is typically found common in most one piece cast aluminum wheels. However, product defects, non-hubcentricity, improper offsets, and, leaks, etc., may also occur in higher dollar two, and, three piece wheel construction, as well.
Now, despite the existence of such inherent manufacturing issues that may even appear in multi-piece wheels, there is quite a bit more technology, improved metalurgy, fitment, finishing, Q/A, and, testing that is involved in the making of a multi-piece wheel. Hence, multi-piece wheels will cost more. Moreover, technology is not only merely relegated to the United States. In fact, some of the best Formula 1 Racing wheels are made in Spain. Also, some of the most exotic wheel designs, cutting edge wheel application upgrades, and, the inclusion of multiple and higher level metalurgy, advanced materials, and, testing, occur in Italy, Germany, Taiwan, and, Japan. Best Wishes to all.
Terry
Bought from another forum member -- I think they were originally from House of Wheels.
They are flawless, and dead straight and smooth.
Seriously, great reply and worth the read.
1. Increased unsprung weight/greater rotational mass. The difference between the weight of my stock Z06 wheels and my American made repros is about 6lbs per wheel! Your car will be noticeably more sluggish. If anyone says different they aren't driving hard.
2. Inferior quality. When it comes to wheels you get what you pay for. here's my personal experience. The clear coat is peeling off the polished lips of my Motorsport wheels in large sections. I contacted the vendor (who happily took my cash) who then referred me to the actual distributor (gee thanks). To their credit the distributor authorized a no cost return for warranty repair if they felt the peeling wasn't my fault. I thought about it but once I factored in the following it wasn't worth my time (approximate four week turn-around) or money. The cost of un-mounting the tires and remounting them to a set of stock wheels and then unmounting those tires from the stockers to re-mount to the fixed wheels would have set me back nearly $400.00. Hardly worth the trouble. I decided to live with them until all the clear coat peels away or I'll take them to a local wheel repair shop and have them re-finished myself. After, some research I found that this is a very common problem with these wheels.
In the end, I spent about $1500 for my repro wheels, money I should have applied to a set of iForged or CCWs. I would have had better quality and lighter than or equal to stock wheel weight.
-RR
