[Z06] Tire Wear
I just inspected my tires and noticed that the LF is down to the threads on the 1st inch of tire. It has pleany of tread left the rest of the way to the outside of the tire. Do you think when I get new tires I need a wheel aligment?
Gus
I like the way the car tracks now and it feels like it's a "steam roller" since I have more contact area when the car is traveling straight. I know I gave up a little cornering ability, but I figure the slightly wider 275 will offset some of the loss of cornering power taken away by the alignment and to be honest I don't play Mario Andretti on public roads to ever push the car to it's limits so I'll never know the difference.
If that extends my tire life by several thousand miles that's a fair trade off.
So you either have an alignment issue related to lowering, or your factory alignment may be on the high side of the Z06 specs which can be very tough on the front tires.
Good luck
Tom
Good luck
The guy also said that a lot of people who buy Vettes by them for looks and don't like some of the mannerisms they have when they hit ruts in the road so they take them to the dealer and they accomodate them with excessive toe in and such to make them track perfectly straight.
While this post may not be technically perfect (since I'm not a mechanic) - it is based on what I remembered and. in general. the point is that I had the same problem and evidently a lot of other people have also.
The factory setting of -0.7 camber is not that bad but will help cause inner edge wear. A touch of toe-in in the front makes some people happy with the steering response. But any toe, whether in or out, will help wear out tires. Simply put setting toe to anything non-zero means the tire gets partially dragged across the road. Worse than camber in my opinion.
Front Individual Toe: +0.04 degree +/- 0.10 degree
Front Sum Toe: +0.08 degree +/- 0.20 degree
Front Individual Caster: +6.9 degree +/- 0.50 degree
Front Cross Caster: within +/- 0.25 degree
Front Individual Camber: -0.70 degree +/-0.50 degree
Front Cross Camber: within +/-0.25 degree
Rear Individual Toe: -0.01 degree +/- 0.10 degree
Rear Sum Toe: -0.02 degree +/- 0.20 degree
Rear Individual Camber: -0.68 degree +/- 0.50 degree
Rear Cross Camber: within +/- 0.50 degree
I suggest that if you want better wear and don't mind a slight loss in performance, run with less front camber and near zero toe in the front. The spec band shown above for front camber is -0.2 to -1.2 with -0.7 being nominal. Run closer to -0.2 for better wear. Toe also has a range that includes zero. So, you can run less camber and zero toe and still be "in" spec.
C66 Racing #66 NASA ST2, SCCA T2
AMSOIL Dealer (Forum Vendor)
AMSOIL Preferred Customer Program (Members buy at Wholesale - a savings of about 25%)
(Multiple values are left/right)
Front
Camber -0.6/-0.7
Caster 8.5/8.3
Toe 0.01/-0.01
Total Toe -0.00
Set Back 0.05
SAI 10.8/11.0
Included Angle 10.2/10.3
Rear
Camber -0.6/-0.7
Toe 0.05/0.05
Total Toe 0.10
Thrust Angle -0.00
