How do I remove the battery base? I see 3 large bolts in the center of the box, are there any more ?
Also, I want to remove the battery surround plastic. I see its held at either end. Where else ? I do see at the curve on the bottom of the plastic piece a screw sticking up through a hole in the plastic tab. Was there supposed to be a nut or cap there ?
