Procedure to replace rocker panel
Old Nov 6, 2005 | 10:45 AM
GregP's Avatar
GregP
Default Procedure to replace rocker panel
Need to replace the right rocker panel on Juliet's car, it got into an altercation with a hidden curb in a hospital parking garage. Have the new panel and painted it. Looks like most of the fasteners are easy to get to, but the two rivets at the very front look like you need to remove the door to get at (I sure hope there is some other trick as I don't have a door cradle).
I saw in some old posts many say they are a PITA to replace and a couple who said they had done it and it wasn't too bad.
What are the tricks you need to know, or should I wimp out and drop it off at Tony's?
Thanks - Greg
Old Nov 6, 2005 | 11:31 AM
MyVetteDream's Avatar
MyVetteDream
From: HOW FAST WAS I GOING OFFICER? Los Angeles Hating GM Dealership Service Dept.'s Since Sept. 2004
St. Jude Donor '04-'05-'06-'07
IMHO ... take it to Tony's (Who's Tony anyway? Your body guy I assume.)
That thing is glue onto the car
I don't mind getting my hands dirty, but when they did mine.. it looked like a major PITA. They had to use an air chisel.
Good luck. Hopefully someone else has something better to add...
Old Nov 6, 2005 | 12:50 PM
GregP's Avatar
GregP
"Tony's" is Tony's Corvette in Gaithersburg.
-Greg
Old Nov 6, 2005 | 02:01 PM
BAMF AE's Avatar
BAMF AE
From: The Surgeon General has warned that it's ok to smoke mustangs!
St. Jude Donor '06-'07
You know............ TONY!!!!!! TONY!!!! The pizza guy on 34th and 168th down in the bronx. TONY!!
Old Nov 6, 2005 | 05:51 PM
TheLaserShop's Avatar
TheLaserShop
Thanks - Greg
The rivets hold the two parts together. There are a few screws on the top of the door sill. The rest of it is totally glued to the frame all the way around. It will come off in about a hundred pieces. Its kind of a big deal. Alignment of the new rocker is critical.
To Procedure to replace rocker panel
