A/C leave it on always?
Old Nov 6, 2005 | 08:23 PM
speedy-vet's Avatar
speedy-vet
St. Jude Donor '06-'07-'08
Default A/C leave it on always?
Now I'm doubting.... I was asked if I turn on my car with the A/C on. I said I always leave it alone, so ... Yeah, It's on when turning it on...
his advice was 'no, you shouldn't' Not good for the car.
I don't have a clear explanation of why but this person drives a brand new C6!
Your input to this would help me learn more about what's best for the car. Thanks
Old Nov 6, 2005 | 08:25 PM
jrose7004's Avatar
jrose7004
I leave mine on! I'll watch this thread!
Old Nov 6, 2005 | 08:31 PM
Humanoid 2.0's Avatar
Humanoid 2.0
St. Jude 15 Year Donor
Cruise-In VII Veteran
St. Jude Donor '05 thru '19
I leave mine in auto; I don't see why it is an issue. The A/C compressor is not always engaged and I would guess during the initial start up it is not.
Old Nov 6, 2005 | 08:33 PM
Prosecutor's Avatar
Prosecutor
Old Nov 6, 2005 | 08:42 PM
C6~Missle's Avatar
C6~Missle
I keep the AC on only when needed. I always start the car first and then turn on the climate control when needed. I only have the AC switched on when necessary... I don't like the way the system constantly uses the AC compressor when all you need is the vents working.
The compressor is a wear item... it also reduces MPG... I understand that these units are more efficient and don't consume much power... but why have it engaged when its not needed...
Its easy enough to switch on the AC when I need to de-humidify or cool the car down... I had the manual system in my 99 and prefer that to the automatic system in my 04...
Old Nov 6, 2005 | 08:43 PM
PA_BLUE_C6's Avatar
PA_BLUE_C6
St. Jude Donor '05-'10-'12, '15
There is a parameter (G0102) called A/C enable rpm that sets mininum rpm the compressor will kick in
Noe
Old Nov 6, 2005 | 08:57 PM
MagikDraggin's Avatar
MagikDraggin
Cruise-In IV Veteran
Cruise-In V Veteran
How do you engage the 'vents' without the compressor coming on? I never have been able to figure out how that works, as there are plenty of times, I could get by with only outside air coming in simply from the forward motion of the vette traveling down the road.
Old Nov 6, 2005 | 09:01 PM
speedy-vet's Avatar
speedy-vet
You mean you only want the vent? I previously posted this question and learned here that when both bottons are ON (A/C & vent) just press the A/C button for 2 sec's and it goes off. The only light on is the Vent button and the A/C will not come on.
Old Nov 6, 2005 | 09:18 PM
FrankMark's Avatar
FrankMark
I have another GM vehicle that now has over 60K miles on it and it is over 7 years old. Since I purchased it new, I have always kept the Air Conditioning on and let the system sense if the cold air is needed or not. So, that system is still working great with no problems. I just keep it on "auto" and let it do it's thing. And by the way I still average 28 to 30 miles per gallon highway driving at 70 mph.
Old Nov 6, 2005 | 09:20 PM
RonJ's Avatar
RonJ
I never knew that!!!!!
RonJ ....
Old Nov 6, 2005 | 09:29 PM
NSTG8R's Avatar
NSTG8R
Old Nov 6, 2005 | 09:34 PM
Red C6 Z06's Avatar
Red C6 Z06
St. Jude Donor '05 '09
I keep mine turned off when the top is down! Duh!
Old Nov 6, 2005 | 10:57 PM
MY1STPEWTER's Avatar
MY1STPEWTER
All I've used lately in the nice weather, vents and fan. It did take a while after I got the car to figure it out though.
Old Nov 6, 2005 | 11:07 PM
speedy-vet's Avatar
speedy-vet
RonJ ....
I share the opinion of many here...."it's a great forum"
Old Nov 6, 2005 | 11:36 PM
falconfling's Avatar
falconfling
Default Most of the mfgs. state the ac is always on
anyway, that is it operates to dry the air, even when the heater is being used. Makes sense.
Old Nov 6, 2005 | 11:41 PM
MagikDraggin
Cruise-In V Veteran
RonJ ....
I never knew that either.....but now I do. Thanks to those who are 'in the know' about such things.
TWO thumbs up for you guys
Old Nov 7, 2005 | 12:32 AM
lpabsolute's Avatar
lpabsolute
Not sure why but if i do have my air on, i always turn it off before getting out of the car...
To A/C leave it on always?
Old Nov 7, 2005 | 12:39 AM
lpabsolute's Avatar
lpabsolute
Old Nov 7, 2005 | 01:08 PM
I don't switch the A/C off on my car when I shut it down. So, when it starts back up, whatever setting it was on comes back on.
Old Nov 7, 2005 | 01:34 PM
pastorbrad's Avatar
pastorbrad
St. Jude Donor '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17-'18-'19
Maybe it's my imagination, but I can perceive the power difference with and without the compressor engaged.
