My vet (2000 C5 automatic) has run like a dream since I purchased it, no problems at all. The other day as I entered the highway and got up to about 55-60 mph my front end and steering wheel started to shake like never before. I backed off the gas down to 45mph and it stopped then I got her up to 60 mph again and it started shaking again and the front end feels bouncy.
I checked the air pressure and all four tires are at regulation.
I have had a front and rear end alignment (within a month ago) and it was computered with print-out as .02 and .04 which is basically perfect for the fronts.( I just looked at the old print-out for the specks).....so now what do I do??
Thanks guys.
A wheel weight might have fallen or been knocked off and now you just have a wheel out of balance. Check and balance all four tires before you look for something more complicated in the suspension. Good luck.
