Compass/temp gauge option?
Old Nov 7, 2005 | 02:57 PM
RoadReady's Avatar
RoadReady
Default Compass/temp gauge option?
I was looking at a C5 on Ebay this morning and among the options was listed "Compass/Temp Gauge". I ran a search on descriptions and came up with some others that listed this as an option, including a 2002. My owners manual makes no mention of this device, nor does the dealer order sheet I found on CAC.
Is there such a such a device on C5s? If there is can it be retrofitted? If there is not, what made all these guys think it is an option?
Old Nov 7, 2005 | 03:38 PM
RocketDawg's Avatar
RocketDawg
CI 6-7-8 Veteran
St. Jude Donor '09
They've all got an outside temperature sensor (or at least the newer ones do), but I don't know of a compass option. It's probably aftermarket if he's got one.
Old Nov 7, 2005 | 03:41 PM
Lovin It!!! - C5's Avatar
Lovin It!!! - C5
I believe this option is located on the Self Dimming Rearview Mirror. I've seen several posts on how to install them on prior years. On cars without this option the OAT is displayed on the AC display on vehicles that have the Automatic Climate Control Option.
HTH
Old Nov 7, 2005 | 04:02 PM
Humanoid 2.0's Avatar
Humanoid 2.0
St. Jude 15 Year Donor
Cruise-In VII Veteran
St. Jude Donor '05 thru '19
The compass is not an option, it must be after market. The outside temperature is displayed on the auto climate control.
Old Nov 7, 2005 | 04:30 PM
RoadReady's Avatar
RoadReady
HTH
I have both the electronic self-diming mirror and the climate control system, and there is no compass in either one...unless there is something not in the manual. Think I'll ask one of these sellers how it works.....
Old Nov 7, 2005 | 04:40 PM
MTurnbo's Avatar
MTurnbo
I have a 2000 vert without the auto dimming mirror. Would love to add it. Is this a relatively easy mod?
Old Nov 7, 2005 | 05:39 PM
LB04CE's Avatar
LB04CE
Auto Dim here,, no compass..........
Old Nov 7, 2005 | 06:05 PM
PEW01's Avatar
PEW01
Old Nov 7, 2005 | 06:12 PM
MYRagtop's Avatar
MYRagtop
Got a compass in the Venture, but not in the Vette. WTF.
Makes perfect sense to me.
Old Nov 7, 2005 | 07:32 PM
screw991le's Avatar
screw991le
From: Redsox, Pats, Celts & Bruins !!! Redsox Nation !!!
St. Jude Donor '06-'07-'08-'09-'10-'11-'12
Donnelly and Gentex make the mirror you are talking about. The C5 never came with the compass in the mirror.
Just search ebay for the two names listed above.
But good luck finding one with entry lighting attatched for under $300
Old Nov 7, 2005 | 08:33 PM
Lovin It!!! - C5
Sorry, I drive a lot of different GM vehicles. Just assumed that if I started seeing this switch from AC display to the mirrors four years ago on the cheap car, surely the Vette would have had one by 03 or 04 (mine's a 00). They do make good ones for after-market.
I bought one of those and installed it on my 84 Camaro with Self-dimming, Compass, and OAT. They are around $200 with map lights, compass, and with or without OAT.
Without OAT $189
With OAT $229
Very simple install. Especially if you get the one without the OAT
To Compass/temp gauge option?
