I am looking to buy some c6 motorsport wheels 18x8.5 and 19x10 and would like to know has anyone put thee on your c5 and how was the offset? i have notice that the c6 rears are 78mm offset do they stick out alot. Any pictures would be alot of help.
Here are my wheels, in 18x8.5 and 19x10. No fitment issues whatsoever.
Thanks you car is very nice and those are the exact same rims that i am looking at . Can you tell me the tire size that you are running?? on the rears. And did you need a spacer for the wheels
Give either Nate at Corvette Garage or Matt at Corvettes of Houston a call. They can answer all your questions. I don't think you need any spacers if you buy the wheels that are made for the C5.
I have GM C6 wheels with the C6 offset and they seem to fit fine...they are a little tight on the back of the wheel. When its lifted the inside of the wheel/tire slightly touches the back of wheel well as the tire/wheel hangs down and goes inward. But other wise they have never touched. I put some pics below:
The tires are Bridgestone Potenza RE050A 245/40/18 front and 285/35/19
Im trying to do the same thing... looking for C6 motorsport wheels and probably in 18-19 inch combo. I've a huge thread going on that, check it out. Only problem is that if they not GM factory rims, and are reproduction rims (which they usually are), then you'd have to sacrifice the quality. They reproduction rims are definitely heavier, and add to the unsprung weight to the wheels. I have Magnesium rims, which are supposed to be the lightest C5 wheels. I'm still debating whether I should go for looks or performance.... (for wider rims, I'm also considering Z06 rims. Wish they made them in chrome)
Thanks For the pictures One of the other problems i have is do i get a 10 or 11 inch rear rim I am puting on 295/35/19 and i know it will fit both. I am just not sure how it would look on the 11' rim
Im running 245/40/18 in front and 285/35/19 in the rear. Tires are BF Goodrich KDW's
