warm air on passenger side
Old Nov 9, 2005 | 01:19 PM
ronnie948's Avatar
ronnie948
Cruise-In III Veteran
Default warm air on passenger side
Now I find that warm air is coming out of the passenger air conditioning ducts, The air coming out of the drivers side is cool but not as cold as should be. I went and had the system checked and recharged and still have the problem.
Ever since I went to the dealer and got the drivers side window repaired I have had nothing but problems. That nightmere is on another thread.
My guess is when the mechinic unhooked the battery He just left everything turned on and screwed a lot of things up.
Column lock harness in the steering wheel
CD changer (12 pack in trunk)
Regulater in drivers door
Window modulater
and now the air conditioner passenger regulater switch
If anyone knows a fix for this without me going back to that $#*&^ dealer please inform me of the fix.
Old Nov 9, 2005 | 05:49 PM
Der Flieger's Avatar
Der Flieger
Default Hvac
Check for codes on the DIC. If you have any, reset them and try your system again. The HVAC has a history of setting codes during maintenance, and will not work properly until the code history is reset.
