First Vette Purchase
Old Nov 10, 2005 | 09:48 AM
joe.budzynski's Avatar
joe.budzynski
Default First Vette Purchase
Hey everyone!
I found this forum while browsing around for things to pay attention to when purchasing a Corvette. In the general info thread, I read some great information about what to look for.
I'm currently considering two Corvettes, as follows:
Vette 1
2000 Convertible
Triple Black
15000 miles
Owner is asking $29000 (KBB is $28450)
Nearly all options (HUD, Memory seats, Active Handling)
Vette 2
1999 Convertible
Silver, Black Top, Black Interior
43000 miles
Owner is asking $26900
Options include Active Handling, but no HUD
I've looked at and driven both of them. As a result, I'm pretty much settled on the 2000 Black Convertible. However, it has one problem that I'm not sure how severe it can/could be, or if it's not really an issue.
Basically, when looking at the front end, underneath by the metal guard that is supposed to protect the fiberglass from speed bumps, higher curbs, and such, the fiberglass is split near that metal guard (About a 3 inch crack) on the passenger side. The metal guard is not dented, nor out of place, and the rest of the underside looks good. The crack is not visible when looking at the car normally, only if you are looking from underneath. My fear is the crack will eventually work itself to the front of the bumper.
Do any other Corvette owners have experience with this sort of thing? Does the split continue growing? Is this a deal breaker and I should walk away from the car?
Old Nov 10, 2005 | 09:56 AM
BlueL36's Avatar
BlueL36
Cruise-In V Veteran
Cruise-In VI Veteran
Hiya Joe
The crack, from your description, doesn't seem to be a drawback at all. A number of folks have scraped the bottom of the nose. I've got a few scratches on mine. With fewer miles and one year newer, it seems like the better deal of the two.
Good luck with your decision.
Old Nov 10, 2005 | 11:07 AM
jaxgator's Avatar
jaxgator
From: Time is a great teacher. Unfortunately, it kills all its pupils.
Cruise-In VIII Veteran
St. Jude Donor '07
Originally Posted by BlueL36
Hiya Joe
However, if the crack ever does present a problem you could just replace it with a Tiger Shark nose. That's what I would do.
Old Nov 10, 2005 | 11:45 AM
blacksedan87's Avatar
blacksedan87
St. Jude 15 Year Donor
From: "It's 106 miles to Chicago, we've got a full tank of gas, half a pack of cigarettes, it's dark, and
St. Jude Donor '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17-‘18-'19
Welcome to the best forum on the 'Net, Joe!
If you're interested - one of the members here has the ability to run VIN's through the GM VIS system to obtain service and origination history. This information will tell you build date, options as ordered, in service dates, originating dealer and most importantly at this point, what service has been perfomed on the vehicle by the dealer's service departments. It will also tell you if there are any outstanding recalls, or if all recalls have been performed.
I would suggest that you send a private message to CF Member Sponge Vette provide him with the VIN and ask if he'll run both for you. I am a big believer in arming yourself with as much information about your perspective car as possible - before you make a decision.
Good luck with whichever you choose! You'll love the C5 as much as the rest of the crazies around here!
Old Nov 10, 2005 | 01:47 PM
mitch.smith's Avatar
mitch.smith
Spend the few extra $$$. You will be glad after it is done. When I first started looking for a vette I was going to get a used one. I was looking at a 2000 vert with 36k on it. It was priced at 34K. I wound spending a few $$ more and wound up buying a new on 04 with full warranty. I have had it a year and less that 5K on it now. Bottom line go with the less miles and year newer just my two cents and good luck!!
Old Nov 10, 2005 | 03:45 PM
joe.budzynski
Thanks for the advice everyone!
I put in an offer on the 2000 Black Convertible, and he accepted, so come this weekend I'll be the new owner! This is unbelievable!
To top it off, this is the first car I've ever purchased on my own, without the help of my parents
I'll try and post some pics or something when I finally have it. Again, thanks for the suggestions!
Old Nov 10, 2005 | 03:47 PM
flyzlow's Avatar
flyzlow
Congrats on both counts! Welcome!
Old Nov 10, 2005 | 06:35 PM
Congrats. I think you made a good choice.
Old Nov 10, 2005 | 06:41 PM
CCA Corvette Parts's Avatar
CCA Corvette Parts
Premium Supporting Vendor
St. Jude Donor '07-'08,-'13-'14, '16-'17
Welcome to the Forum!
Since it is on the underside of the car, and no one will see it, you can go to a boat supply store and get a fiberglass repair kit and "Patch" it or overlay it yourself... Very easy to do... I've done it a bunch of times on jetski's and boats.
It will stop the spread of the crack...
Peace
Willfulone
__________________
..................Click for
Old Nov 10, 2005 | 09:18 PM
GrayC5's Avatar
GrayC5
Congrats ...and welcome to the Forum!
Old Nov 10, 2005 | 09:27 PM
DAS ZED's Avatar
DAS ZED
Congratulations, and welcome!
ELTGuy_C5's Avatar
ELTGuy_C5
St. Jude Donor '05
Went with the 2000 eh? Wise move... welcome to the forum
Old Nov 10, 2005 | 10:19 PM
jlbruggeman's Avatar
jlbruggeman
Congrats, I'm sure it's a great car-You'll enjoy the performance of a nice fresh LS1!
Old Nov 10, 2005 | 10:26 PM
Mike98SilVert's Avatar
Mike98SilVert
Active Streak: 90 Days
Congrats
Great choice
Old Nov 11, 2005 | 03:35 AM
NOWUCME's Avatar
NOWUCME
C6 of Year Finalist (stock) 2019
Default The Broken part
About the crack or split under the car. Go to a auto parts store and get a small plastic resin kit. some come with a small mesh screen or fiberglass. You just mix up some of the resin as it comes out of the double tube. Clean the surface and put some on then the mesh or fiberglass....let it dry and then put some more resin on it..
Works great where you cant see it but you could sand and spray a little paint on it too. I use one recently that was marine quality...seemed to be a little harder than the other.
Will firm up the split and probably won't get any worse unless you hit it again..
Sounds like a great car, better to go for the low miles......Have fun
To First Vette Purchase
