[Z06] trans fluid ?
Old Nov 12, 2005 | 05:32 PM
1320IN9's Avatar
1320IN9
Default trans fluid ?
changing the fluid this weekend, should i use regular dexron 3 or mobil 1 atf
Old Nov 12, 2005 | 09:02 PM
Cruncher's Avatar
Cruncher
When my Z06 was new, I started having problems shifting into 5th (always Grrrrrrr Grrrrrr Grrrrrr). The OEM trans fluid was checked & it wasn't too red. I had Mobil 1 ATF put in & haven't had a problem since. In fact, shifting through all the gears was improved.
Old Nov 12, 2005 | 10:17 PM
SGT. PYLE's Avatar
SGT. PYLE
I run RedLine D4 ATF and have had no problems. You will get alot of different opinions but I am sure that all synthetic ATF is relatively the same.
Old Nov 14, 2005 | 10:34 PM
C66 Racing's Avatar
C66 Racing
Premium Supporting Vendor
There are many good synthetics that meet the Dexron III standards. I use AMSOIL ATF for my car which sees exclusive track use.
__________________
C66 Racing #66 NASA ST2, SCCA T2
AMSOIL Dealer (Forum Vendor)
AMSOIL Preferred Customer Program (Members buy at Wholesale - a savings of about 25%)
Old Nov 15, 2005 | 04:20 PM
Michrider's Avatar
Michrider
I'll second the Amsoil ATF. Works great in my 04. Meets the right spec and easy to find at most auto parts stores.
To trans fluid ?
