[Z06] Oil Change
Old Nov 12, 2005 | 08:09 PM
RB6's Avatar
RB6
Cruising
Default Oil Change
I have an 04 zo6 I bought new, when I bought it there was only about 5 miles on it,I currently have about 6000. I have not had an oil change yet, the manual recommends 15000 miles on mobile 1 before a change. Is there a length of time that this should be done, like 6 months, a year or is oil good for the 15000 miles regardless of the time it is in the engine?
Old Nov 12, 2005 | 08:25 PM
RoHo's Avatar
RoHo
I have an 04, and changed the oil and filter the first time at 500 miles to be sure there were no small partical from the new engine floating around, second change at 1500, third change at 3000, I don't care what the manual says, oil is cheap compared to a rebuild and its the life blood of your engine.
By all means change it now.
Old Nov 12, 2005 | 08:32 PM
Shylor's Avatar
Shylor
If you actually looked at the manual you would see, it says to follow the DIC or 12 months, whichever occurs first.
Old Nov 12, 2005 | 08:53 PM
1320IN9's Avatar
1320IN9
get that oil changed ASAP then do it evry 3000 miles from there on out
Old Nov 12, 2005 | 09:05 PM
3 Z06ZR1's Avatar
3 Z06ZR1
yes lad change least 2 per year or every 3k
Syntec
Old Nov 12, 2005 | 09:59 PM
Shylor's Avatar
Shylor
3000 miles is way to short of an interval for synthetic oil and is a waste of money. Let go of the 60's belief, your engine won't last any longer with 3000 mile oil changes. Just change it once a year or when the DIC tells you to. If you must change something earlier, change out the oil filter (it's easy to get to).
Old Nov 12, 2005 | 10:15 PM
SGT. PYLE's Avatar
SGT. PYLE
Originally Posted by Shylor
3000 miles is way to short of an interval for sythetic oil and is a waste of money.
I waste Alot of money .
Old Nov 12, 2005 | 10:58 PM
Steve Carter's Avatar
Steve Carter
Let's see...$50,000 car $50.00 oil & filter change.
1). @ 500 miles
2). @ 1000 miles
3). @ 3300 miles
Next, spring
Z16 ZO6
Old Nov 13, 2005 | 12:44 AM
l2vette's Avatar
l2vette
Old Nov 13, 2005 | 02:32 AM
SMFCPACFP's Avatar
SMFCPACFP
Cruise-In II Veteran
I change mine when the DIC indicates a change is needed (less than 5%). GM is very conservative.
Conventional wisdom is that oil should be changed every 3,000 miles. This conventional wisdom refers to a time when castor oils were used in cars, before petroleum based oils, before synthetic oils - in other words a long time ago. We are talking about the first decade of the last century.
Castor oils are vegtabled based. They are a great lubricant, but don't last very long (they have a very low flash point). This is where the 3,000 mile rule came from - the 1908 period. Somehow it has stuck to this day. Of course it makes no sense today. It is just an old adage. It doesn't hurt to change it that often, just like it wouldn't hurt to wipe your dipstick with a $100 bill after you check the oil and throw it away. I don't do that either.
As a shareholder of Exxon Mobil, I thank you guys who change your oil every 3,000 miles. If that makes you feel good, why not change it every 500 miles. Think how much better you would feel.
Old Nov 13, 2005 | 06:29 AM
Shylor's Avatar
Shylor
The cost of the car doesn't change the fact that 3000 mile oil changes are not needed. Again, your engine won't last any longer than mine by following the DIC.
Old Nov 13, 2005 | 10:51 AM
bobby777's Avatar
bobby777
Im sure at 6000 miles your motor is ok-but I would change now and go every 5000 miles for oil/filter--Also get a magnetic drain plug.
Old Nov 14, 2005 | 10:32 PM
C66 Racing's Avatar
C66 Racing
Premium Supporting Vendor
As mentioned above, the manual does not say to go 15k miles, but rather to change the oil when indicated by the oil life monitor, or at 12k miles, whichever comes first. Depending on how you drive, you may get between 6 and 10k before the oil life monitor says to change your oil.
__________________
C66 Racing #66 NASA ST2, SCCA T2
AMSOIL Dealer (Forum Vendor)
AMSOIL Preferred Customer Program (Members buy at Wholesale - a savings of about 25%)
To Oil Change
