trunk partition on a C5
Old Nov 12, 2005 | 10:52 PM
Frank55's Avatar
Frank55
Default trunk partition on a C5
Why was the trunk designed to be open into the cockpit? Will blocking the opening with a partition cause any problems?
Old Nov 12, 2005 | 11:16 PM
c5BlackBeauty's Avatar
c5BlackBeauty
Lifetime Member
St. Jude Donor '05, '12-'13, '15-'16, '21
Not sure....perhaps the designers thought it would save some weight, but the openess does add to increased noise in the cockpit as well as poor stereo performance. The partitions help in both cases. Do a search and you'll find many forum members who use partitions and are please with the results.
Contact Crazy C5 Cowboy to get one. Great guy to work with.
http://www.exoticvette.com/Exotic%20Vette/index.htm
Old Nov 13, 2005 | 09:20 AM
CHJ In Virginia's Avatar
CHJ In Virginia
Partitions were not included because of storage space. You have more space for items like golf clubs and can actually get two bags in the car without a partition. I put one in my Z06 and it dramatically cut down the inside cabin noise level. I now have to figure how to cut the partition to accommodate the rear braces on the roll bar recently installed. I definitely like the reduced noise on road trips.
Old Nov 13, 2005 | 09:34 AM
Markm10431's Avatar
Markm10431
Parrothead
St. Jude Donor '08-'09,'13, '14
Im not sure you can add a partition on a vert without blocking the top's ability to fold down so I think I'm stuck with it
Old Nov 13, 2005 | 09:52 AM
GeorgeB's Avatar
GeorgeB
The Exotic Vette one has a little angle in it so you can fold your top down AND get to the center rear storage compartment without having to remove it.
Old Nov 13, 2005 | 11:14 AM
southerncarparts's Avatar
southerncarparts
Supporting Vendor
St. Jude Donor '06-'07, '13, '15
They work fine with the top up or top down.
We also have them in Black, Light Oak and Pewter/Grey.
Old Nov 13, 2005 | 01:12 PM
Markm10431's Avatar
Markm10431
Parrothead
Thanks!
Old Nov 17, 2005 | 09:56 AM
Crazy Cowboy's Avatar
Crazy Cowboy
Premium Supporting Vendor
From: www.EXOTICVETTE.com - FL Cruise-In VI, VII, & VIII
Cruise-In V Veteran
St. Jude's Donor '05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16
No problems, as long as it's designed right to clear the top. The new C6 power top vert has a factory one
www.ExoticVette.com
Old Nov 17, 2005 | 02:49 PM
Conk's Avatar
Conk
Several members have made their own homemade (and very nicely made) partitions for about $20. A piece of thin plywood or heavy cardboard, surfaced with cheap carpet. Glue a little border around the edge and bingo - over a hundred dollars saved! Search and find the simple instructions/directions to make your own. Forgot who posted them, but they're good.
Old Nov 17, 2005 | 03:04 PM
edensknight's Avatar
edensknight
Ya just gotta doff your hat to the very capable and resourceful DIY.
Old Nov 17, 2005 | 04:33 PM
NCSU SEE 5's Avatar
NCSU SEE 5
From: Greensboro, NC "REALITY IS MERELY AN ILLUSION, ALBEIT A VERY PERSISTENT ONE"...ALBERT EINSTEIN"
St. Jude Donor '05-'06-'07
Love Mine! Works Great!
To trunk partition on a C5
