When I approached my baby this morning, I noticed that one of the rear tires has a nail stuck in the tread. Tire pressure hasn't changed.
I've got 20,000 miles on my original tires and I'm probably 3 to 5K from having to buying new tires anyway. So, I debating plugging the rear tire and riding it out for about 4 months or just biting the bullet and going ahead with buying a new set of 4.
Anyone have any sage advice? Thanks.
As any good hostess would say "Up to you"
All kidding aside, I had a similar problem not too long ago & thought about changing out all the rubber. I took the car to Goodyear and they said the tires still had a lot of life remaining (in my case) and recommended a patch & plug. So Goodyear made $40.00 on me instead of $1200.00 on their recommendation
The one thing that should be a factor is safety, I'd have the tire plugged & patched (from the inside)... It seems that's the way to go & the cost is nominal. Think it took about an hour to complete as well.
I would plug it and get those last few thousands of miles out of them.
I had a right rear tire FLAT warning 2500 miles from home. Put in a plug, reinflated with a portable compressor...went to the tire dealer for a better fix and he told me to just leave it, semi trucks under load come in with as many as 10 plugs. I put on another 10,000 miles before changing out the set.
Can't fix a sidewall with em. I'm not sure about runflats personally.
If I were in your position and getting ready to switch to non-runflats I'd be anxious enough to go ahead and get the new tires. If I were staying with runflats, I'd plug&patch and nurse all the miles I could out of them. My .02 worth.
The school house answer is do not use plugs. Because, prior to inserting the plug, you clean out the hole with the reamer, that comes in the repair kit. This makes the original hole larger. The concern is : rapid deflation if the plug comes out, at speed. By plug, I am refering to the old style , straight plug, NOT the modern plug/patch combo.
I have used plugs several times, over the years and never had a problem. I would not do 175 MPH, with a plug, though.
If you had miles and miles of tread left, then removing the tire and patching would be safer. But with just a few left, plug it and don't pass on the opportunity to do a monster burnout.
Thanks so much to everyone for all the input. I'm taking the plug and patch route. I want to try to get a few more month out of the tires, before I have to pull the trigger on a new set of tires.
From: Lost in the Pine Barrens with only ketchup and relish packs, New Jersey
I went about 20k miles on a plug and patch on one tire of a set that already had about 10k miles on them. The tire shop told me to hold off on a new set and that a patch from the inside will hold very well. They were right and I saved a few bucks!
