C5 tune ?
A basic dyno tune is in the $500 dollar range plus or mins $75 bucks.
As i said in the other thread $425 is not worth it without dyno/street time.
Basically a dyno tune can edit MANY parts of your power train. If you've got an automatic it can adjust shift points and shift firmness. It can adjust for new stall's or different sized tires.
On a manual there's not too many changes you can make except turn off the skip shift.
Now for the engine. You can edit the fans, the timing, the fuel, ect. Also can delete codes, such as your 02 sensor codes. Basically every paramitor required by the motor to run, you can change it with a tune. With your common tuning software <ls1 edit, hp tuners, efi live-edit> You can make edits to the software to compensate for just a few bolt ons, or for dropping in a forced induction 427. It doesn't matter to the software it can edit it all.
NOW, is the $500 worth it?
That all depends on what mods you have, and what mods you plan on getting. If you've done intake and exhaust and deleted the Cat's, it's must easier just to get the tune and delete the codes than taking a chance with the simulators working or not working <they're not 100% for all cars>. But if you do intake exhaust and are planning for a cam, it'd be best just to wait a bit and get it all tuned at once.
With intake and exhaust a dyno tune can be worth as much as 20 horsepower, maybe a little more <we proved that last weekend>. The car ran great without a dyno tune, but Rev Xtreme was offering a good deal so we put Matt 24's vette up there to see what it did.
Most cams <and beyond> are going to require a dyno tune. Your computer willl compensate for the cam, but you may have issues until you get the car tuned. If it's a monster cam, i would recomend a tune along with the cam, if it's a baby cam, go ahead install the cam and drive to a tuner, it shouldn't be a problem.
Hope this helped, i could go on for a while, but think i've explained it.
Chris
Jim
Chris
I'm sorry, when i referred to intake and exhaust...i usually mean Headers too...Muffler's aren't much of a performance mod, by themselves.
Chris
I mean, if you're NEVER going to mod your car again...might as well....Buut, if you're ever going to move on with mods, that tune with that few mods is fairly worthless.
