Does anybody have these on there Corvette? http://cgi.ebay.com/ebaymotors/97-04...spagenameZWDVW I thought about getting a set of them since I have the side markers. How hard would these be to install? Any pics and advise will be greatly appreciated. Thanks!
I don't have this brand. I have the Pro Car Parts signals. Easy to install. 7mm and 10mm sockets are needed. 7mm to remove the lower spoiler bolts and the outer most bolt holding the signal in place. 10mm for the inner bolt. There is a spring in the center. After removing the lower spoiler and plastic covering, you need to push the brake cooling duct out of the way. Doesn't take long and isn't hard. Hope this helps.
I put the same clear lights on my yellow coupe last week, they look great. Have a couple pics that I can't post. They are pretty easy to put in just takes awhile, didn't take me as long to lower on stock bolts as it did to put those lights in. I can e-mail pics to you. PM me with your address.
if you buy it from EBay, and going to use PayPal to buy the lenses, use promotional code:
C3-Holiday2005
to knock $15 off $100 purchase. So it ended up cheaper for me compared to buying from their website. (They wanted $15.xx for shipping instead of $12.99 on their website), so i ended up paying $98.98 for the set on Ebay w/ paypal purchase. If we are not allowed to post codes here... mods, plz delete, i apologize!! Enjoy!
Here are pics but not on a yellow vette, used yellow bulb so I have the eggyolk look. Will try and find some clear next year with amber illumination. Tried LED's but needed a load equalizer-too much work for me.
Here are pics but not on a yellow vette, used yellow bulb so I have the eggyolk look. Will try and find some clear next year with amber illumination. Tried LED's but needed a load equalizer-too much work for me. Oooops sorry double post.
