Gas Gauge Problem
Old Nov 14, 2005 | 06:41 PM
PVHolgado's Avatar
PVHolgado
Default Gas Gauge Problem
My gas gauge reads empty even though I know tank is full- Check gauge light on also-- Any ideas... help--
Old Nov 14, 2005 | 06:43 PM
Goonie's Avatar
Goonie
gas gauge common problem... scroll through the forums...
get the codes and post em for the check engine light.
Old Nov 14, 2005 | 07:40 PM
scottydog's Avatar
scottydog
Mine did the same. It's a bad fuel sending unit. I hope you're still under warranty. It's a known problem which GM probably should do a recall for but won't.
Old Nov 14, 2005 | 08:07 PM
Donzi4me's Avatar
Donzi4me
Happens alot... Techron....
Old Nov 14, 2005 | 08:42 PM
C5Jim's Avatar
C5Jim
I had the same problem driving back from Detroit back in August. I knew I had a 1/2 tank, then all of a sudden.....empty, with a message on the DIC saying "Get gas now". I said to my wife "look, the car thinks you're driving" (she never fills up the car till it's bone dry).
Any way, at Corvettes at Carlisle, at the Chevy tent, they had a table set aside that read "Technical Help" from GM engineers.
I asked about the fuel gage problem and was told they (GM) are aware of the problem and feel the problem is with fuel having high sulfur content. He went on to say that it does not happen in all parts of the country.
The cure.....he told me to use Techron. As a matter of fact he told me to use 2 bottles.
I did, and I've had no troubles since.
Old Nov 15, 2005 | 12:43 AM
1998 GTR's Avatar
1998 GTR
The problem is . . . . . . . . . . . . . . .
. . . It's a C5!
Everyone I've talked to has had this problem. Techron did NOT cure the problem for me. I just live with it. It comes and goes. Mine seems to go away with turning the ignition off and then back on. Some say it's the sensors, but I've heard of people who have replaced the sensors and still had the problem reappear. Seems to me to be more of a PCM glitch???
Old Nov 15, 2005 | 03:55 AM
edensknight's Avatar
edensknight
It is a common problem. Try adding the Chevron Techron fuel additive as prescribed.
Old Nov 15, 2005 | 10:01 AM
RatedX's Avatar
RatedX
From: Spring Hill, Florida Life is all about new beginnings;...TRY ONE!
St. Jude Donor '07-'08
....Fixed the problem before I got back from the gas station!
Old Nov 15, 2005 | 10:40 AM
Blindfingers's Avatar
Blindfingers
. . . It's a C5!
Techron is bandaid. The real fix is to replace both fuel sending cards internal to the tanks. My understanding is the high sulfur gas etches the cards making the float/sender unit useless.
Big $$ as the tanks must be dropped. Luckily I got our 2001 fixed under warranty.
Bob
Old Nov 15, 2005 | 10:45 AM
rws.1's Avatar
rws.1
There are several fuel system cleaners that are your first option.
Techron, Berryman Chemtool B-12, BG 44K. If this works after a few tankfuls switch to a top tier gasoline to prevent reoccurence
www.toptiergas.com
It is also possible that you have a losse, or corroded ground. There is a post with great photos and location description.
At last resort replace the sending unit
Old Nov 15, 2005 | 11:01 AM
blacksedan87's Avatar
blacksedan87
St. Jude 15 Year Donor
From: "It's 106 miles to Chicago, we've got a full tank of gas, half a pack of cigarettes, it's dark, and
St. Jude Donor '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17-‘18-'19
Bob
I agree with this to a point - the real issue is the high sulfur content of many of the commonly available fuels. The Techron seems to dissolve the sulfur build up. Replacing the fuel senders is only a temporary fix if you continue using high sulfur fuel. It seems to only make sense that the problem will return with brand new senders.
I use Chevron exclusively and have no issues. If Chevron is not available in your area - Texaco fuel also has Techron in it now. Or, as rws.1 pointed out - you can purchase Techron fuel additive in your local auto parts store and add it to the fuel tank BEFORE you add the fuel. That way when the fuel goes in - it will mix up the addidtive.
Old Nov 15, 2005 | 12:15 PM
Mark S.'s Avatar
Mark S.
Switched from BP (Amoco) to Texaco/Shell and I haven't experienced the problem in over 2,500 miles...
Old Nov 15, 2005 | 12:19 PM
jrose7004's Avatar
jrose7004
Run some Berrymans or Techron thru there a couple of fillups!
Old Nov 16, 2005 | 01:08 PM
vettexan's Avatar
vettexan
Active Streak: 90 Days
Mine is at the dealership now - but I have a different gas gauge problem - filled the tank up and when re-started the gauge went to E. Tech called today and it seems that the baffling in the tank came loose and snagged the sensor which fried it. Now I have to wait for a new gas tank and sensors to be shipped
Old Nov 16, 2005 | 03:18 PM
99quicksilver's Avatar
99quicksilver
Switch to Chevron Gas every other tankful and it should go away.....If not then buy a few bottles of Techron and keep them handy....
Old Nov 16, 2005 | 05:06 PM
jmushockjr's Avatar
jmushockjr
Same worked for me so far!
Old Nov 16, 2005 | 06:25 PM
Try running a bottle of Techron through the tank and see if that works. If not, then you may have bad sending units.
Old Nov 16, 2005 | 06:31 PM
SteveDoten's Avatar
SteveDoten
Cruise-In VII Veteran
clear codes, if it's still there, pull the pass side sending unit and clean the contacts w/ brakecleaner and cotton swabs, i did this on my '98 and it's been good for the past 6 months
To Gas Gauge Problem
