Lowering the car
Nov 15, 2005 | 03:21 PM
Lowering the car
Should I notice any difference after lowering my stock 97 C5 1"?
I'd do a search for it but at this point on the forum the search function is missing from the forum.
Nov 15, 2005 | 03:25 PM
CI 5-6-7-8-9-10 Veteran
St. Jude Donor '07-'08
yeah it'll look like you lowered it 1"
Nov 15, 2005 | 03:34 PM
Agreed....you'll also scrape a bunch of stuff...worth it though.
Nov 15, 2005 | 03:38 PM
You will like the look. One inch will not be that bad. And, yes, the server on this website has been slow and faulty the past few days.
Nov 15, 2005 | 04:13 PM
Make sure you get an alignment after it settles for a couple of hundred miles!
Nov 15, 2005 | 04:19 PM
Quote:
OK good idea, will do!
Thanks guys.
Nov 15, 2005 | 04:20 PM
I hardly ever bottom out, thanks to stangkiller on that mod!
Nov 15, 2005 | 04:34 PM
I believe he got his answer, so i am going to hijack it. How many inches will it be lower if you did it on stock bolts....
Nov 15, 2005 | 04:38 PM
From: Time is a great teacher. Unfortunately, it kills all its pupils.
Cruise-In VIII Veteran
St. Jude Donor '07
Quote:
You can get about 3/4" - 1" on stock bolts I believe, depending on your suspension.
Nov 15, 2005 | 04:58 PM
Quote:
How about on Z51?
Nov 15, 2005 | 05:16 PM
St. Jude Donor '07
Quote:
Originally Posted by saniterium92128
How about on Z51?
I have the Z51 suspension myself and got a minimal drop off of the stock bolts. It was almost unnoticeable to me even though I waited over a couple of weeks and a few hundred miles for it to settle. I got maybe 3/4" and probably more like 5/8" drop. I ended up getting longer bolts for the rear and completely removing the front bolts. After that and putting in Bilstein sport shocks I was happy with the look. Click on my sig pic for a larger view of what it looks like.
