I had mine replaced by a man named Ed Swaneck. Do a search on this forum for the topic and see if you can find his information. It costs around 70 dollars and you have to pull the mirror yourself. However, I can vouch that he does excellent work and I haven't have a problem with it since.
Just found this in the tech section...it's the guy I was talking about. Hope it helps.
I posted this in March of 2003. I don't know if they still do this repair, but I would give them a call if I were you .
"I just read this in my new Issue#150 NCRS DRIVELINE March-April. This Guy will repair "your" mirror with the "broken clip" syndrome. "A permanent repair, guaranteed NOT to break" Send the complete mirror w/wiring harness, with ck or money order for $60.00 inc. shipping and handling. He offers a two day turn around after the mirror is received. He even offers by phone, mirror removal & installation instructions, ph# 330-783-0083 ext.15, after 4:30 pm 330-757-9466. Name & address: E.H. Swaneck, 4030 Simon Road, Bordman, Ohio 44512. Other NCRS members can verify ad, page 66. Sounds like it would be worth a try"
Good luck.
Ed did both of mine, at different times. Fairly common problem.
Ed Swanech
4030 Simon Rd.
Bordman, OH 44512
330 757-9466
Give him a call. Highly Recommended!
I did both sides and I will tell you it is a PITA. If someone will do it for $60, I say go for it. In fact I had to do the driver side twice. (My fix came loose.) I will keep this address for future reference. Good luck.
