NOOB<-----? Jacking points?
Old Nov 17, 2005 | 02:36 AM
SATX_R1's Avatar
SATX_R1
Default NOOB<-----? Jacking points?
Where the heck are the jacking points under this car? I have a very bad back and getting down that far is hard! And I'm only 26...can someone just point this out, I know it's dumb but I'd rather ask then ventilate my floorboard.
Thanks guy's.
M.
Old Nov 17, 2005 | 03:12 AM
rickko's Avatar
rickko
Jacking points are in four locations, front cross member, rear cross member and along the side rocker rails. Those are found either not too far in front of the rear wheels or, not too far behind the front wheels. You can tell where they are as they are kind of an oblong hole where you first insert jacking pucks as seen in pic below.
..rickko..
Old Nov 17, 2005 | 03:16 AM
SATX_R1's Avatar
SATX_R1
So I need to buy some "jacking pucks" to get it off the ground, right?
Old Nov 17, 2005 | 03:24 AM
CCA Corvette Parts's Avatar
CCA Corvette Parts
Premium Supporting Vendor
St. Jude Donor '07-'08,-'13-'14, '16-'17
Yes, but you can make your own. Go to a sporting goods store and buy some hockey pucks and then get some I hooks and screw them into the center of the hockey pucks...should cost you about 5 bucks for 4.
Also the car can be jacked up via the cross member in the front and rear with out pucks...
Peace
Willfulone
__________________
..................Click for
Old Nov 17, 2005 | 05:56 AM
talon90's Avatar
talon90
Cruise-In 11 Veteran
NCM Ambassador
St. Jude Donor '05-'06-'07-'10
with the information above. Rickko and Willfulone have you covered. Here are a few sites with some additional detail.
How to lift a C5
How to make your own lift pads
Paul
Old Nov 17, 2005 | 09:44 AM
MrRenoman's Avatar
MrRenoman
If you don't feel like making 'em you can get 'em on Ebay.
No link here, don't know if it's permitted, but if you copy and paste:
CORVETTE C5 C6 LIFTING BLOCKS / PUCKS
in the Ebay search box, you'll find the auction. $22-23 plus shipping. A little high compare to making your own, but not bad considering gas and time to buy the stuff and assemble.
Art
Old Nov 17, 2005 | 01:00 PM
SATX_R1's Avatar
SATX_R1
Thanks guys.
Old Nov 17, 2005 | 01:06 PM
Gofasterdad's Avatar
Gofasterdad
Just went through this. bugman is the man. Helped me out - big time!
Click on the link and go to Jack
bugman's web site
Old Nov 17, 2005 | 01:38 PM
BobbyG's Avatar
BobbyG
St. Jude Donor '06-'07
This guys got some good stuff here, check it out.
http://97vette.com/
Bob
To NOOB<-----? Jacking points?
