I need help and any input from you guys. I'm looking to get new tires and some chrome wheels for my C5 coupe. (Can't decide on the look of the wheels C6, Z06, or C6Z06 chromies). But my question is does size matter in wheels? What size shall I go with in the FRONT: 17's or 18's ?
Choices: 17X9.5__or__18X9.5? Would it make ANY difference one way or the other in terms of performance ? Tires: 265/35 should do it for me.
(I do wanna keep 18's in the back for sure, probably 10.5 or 11 inch width).
I'm in a lil rush to make a decision, so really need your help . Thanks in advance...
If you intend on upgrading the brakes in the future, now is the time to upsize the wheels.
If you were one of those all out performance/physics purists you could argue the whole rotational inertia thing, which would cause you to question the 18s, which wouldn't allow for big brake kits, which would make you go back to the 18s, which would look better, which will make you happier.....
Thanks for all your replies guys... Yeah, I'm looking at this from a point of physics...well, its more like trying to keep the original "rake". I've been told by many guys to keep the rake of 1.0" to 0.5" inch rake in front compared to rear - specially by ppl who've lowerd their cars. Even while lowering you should maintain the rake_______At least thats what I was told...
Mike, what kinda tire did you go with, I mean what brand. I wanted the GS D3's, they dont come in anything wider than 285. PS2's don't have a 305. Thats another issue though....
the size of the wheel won't have any affect on the rake, the size of the tire could, but it doesn't matter too much since it is adjustable
if you want to run 17s, you could get a 265/40-17 (stock Z06) or 275/40-17, if you bump up to 18s, you would could get something like a 265/35-18 or 275/35-18 so the tire would be almost the same diameter, but would just have a smaller sidewall.
The 18s will give you a slightly better turn in response because of the smaller sidewall, but the 17s will be cheaper and slightly softer. The difference on a street car should be minimal...if you notice it at all.
the other advantage of the 18s is that you will ahve room for a 14" rotors later on.
I run 18x9.5/18x10.5 z06 repo wheels with 265/35-18/295/35-18 tires. Next time I'm going to bump up to a 275/35-18 because of slight understeer at track, but the 265/295 combo is great for a street car.
The critical factor for handling is the tire compound along with the amount of rubber you can put on the road. Since everything is a compromise, determine what is critical for you and make your selection accordingly.
We went with Nitto 555 RII's (285/35 ZR18 & 305/35 ZR18) which kept the front-rear diameter ratio. The R compound and wider tires provided me with a significant improvement at the track...the trade off is the longevity of the tire and reduced performance on wet surfaces.
