Help i need a new rim
Old Nov 20, 2005 | 12:09 PM
SCG620's Avatar
SCG620
Default Help i need a new rim
I help finding an oem 18" polished rim for the rear of a 2000 vette got some curb rash recently and it looks terrible. Hoping to find the rim cheaper rather than going to the stealership and getting robbed for one rim. Thank you.
Old Nov 20, 2005 | 12:18 PM
darkmercury's Avatar
darkmercury
You should try polishing it out... Get a dremel tool and got work on the rough curbed metal! The wire brush wheel should do the trick since the rim is aluminum and soft.
Follow up with rough to fine sanding blocks to shape/blend the lip back to being flat. Then... polish it up with Blue Magic metal polish.
At this point... it can only help until you find a replacement wheel.
Old Nov 20, 2005 | 12:50 PM
Boomah's Avatar
Boomah
Just take your time and I'm sure you can really improve the looks of the rim, a Dremel can work wonders.
I had a similar situation a few days ago with my Z. Of course those are painted rims but curb rash is curb rash and the rims looked pretty bad (think my next mod should be curb-feelers). Anyhow I Dremeled away the rough spots, filled the gouge, touched up with the appropriate color, and polished it out using the Micro-mesh system (it's used on our Eagle windscreens and canopies as well as airliners so I figure it's good enough for my Vette ). So far so good, no one can tell the rims were scrapped by my lack of parking skills & judgment
Again give a go to making the repair yourself & save some $$$. Just take it slow & make sure you protect the unaffected surrounding areas just in case the Dremel gets away from you. One last thing... If you don't want to risk it try a wheel repair specialist. I understand they can work wonders and the cost should still be less than replacing the damaged rim.
HTH
Mark
Old Nov 20, 2005 | 02:03 PM
charlene's Avatar
charlene
St. Jude Donor '04-'05-'06-'07-'08-'09-'10-'11-'12-'13
I tried lots of things on my rim of my 03 i guess i was not as handy as the men giving you the advice on how to make the rim that was scratched look nice but i tried. So i bought a new rim from the dealership and got their employe discount and since i belong to the corvette club out here i got a discount from that to the rim ran me $425 instead of the price on the receipt for almost $700 dollars i think i got a good deal.Charlene
Old Nov 20, 2005 | 04:38 PM
edensknight's Avatar
edensknight
Try polishing the wheel youself as recommended above. Also, Eastwood Company offers many different wheel polishing kits for the DIY'er that are very reasonably priced. As an alternative, you might try locating a professional wheel polisher in your area. Generally, professional wheel polishing is approx. $100 to $125 per wheel. Lastly, you might also try a local chevy dismantler in your area. These used parts facilities will have used wheels. In fact, Gene at the Karshop (supporting vendor) can help you with this issue (purchase a used replacement C5 wheel) at a great price. Good luck to you.
Old Nov 20, 2005 | 06:32 PM
vcarr's Avatar
vcarr
had a hard time finding one myself and after long hrs. on the internet corvettemikes.com was the cheapest for the particular one that i was looking for. good luck
Old Nov 22, 2005 | 06:46 PM
SCG620's Avatar
SCG620
thanks for the advice i tried dremeling the rim but it seems like it made the area dull and the thickness is not the same as the rest of the rim, first im going to try a wheel repair company then if it doesnt work i guess ill bite the bullet and get a new rim.
Old Nov 23, 2005 | 01:49 PM
R3DC5's Avatar
R3DC5
PM'ing you SCG620.
Old Nov 23, 2005 | 02:35 PM
Chicago's Avatar
Chicago
St. Jude Donor '15
Also keep an eye on Ebay. I've been looking for wheels for a while and see single wheels for sale all of the time.
Old Nov 23, 2005 | 03:24 PM
Benpup's Avatar
Benpup
Cruise-In VI Veteran
I had one that cracked. Go to Bobs House of Wheels. Got a great price and great service.
Old Nov 23, 2005 | 05:12 PM
Try Gene at the KarShop in Florida. Bet he can get you one at a decent price.
To Help i need a new rim
