1st, I'm going to remove the logos, so I'll order the stripes w/o the cutouts. I want to stick with the red/black color scheme, so the center section will be black, but I'm not sure what to do with the sides (red on this car). The only thing I could think of was gray, but I don't really like that idea. So any suggestions would be appreciated.
From: "It's 106 miles to Chicago, we've got a full tank of gas, half a pack of cigarettes, it's dark, and
St. Jude Donor '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17-‘18-'19
I would go with white or black. If black is your accent color, then in my mind those are your two choices - white if you want contrast, black if you want a monochrome theme.....jmho.
That's my car in your example photo. I considered going without the red stripes. a black center stripe without the side stripes might look good. Otherwise I would go with black/black.
