[Z06] Loose turn signal assembly......
Old Nov 20, 2005 | 06:11 PM
1983JZR3W's Avatar
1983JZR3W
Default Loose turn signal assembly......
I just noticed on my 2004 Z06 that the right front turn signal/drl lamp assembly is a little loose on one corner. What is the best way to get to that area to tighten it? Do I need to remove some of the inner fender panel or what is the trick to get to it? Thanks in advance.
Old Nov 20, 2005 | 07:27 PM
Twil1ght's Avatar
Twil1ght
There is an access panel on the bottom of the car. The turn signal is held in place with springs.
