[Z06] Rear Stabilizer Bar....Leaking
Old Nov 20, 2005 | 07:12 PM
LIGHTNING's Avatar
LIGHTNING
Default Rear Stabilizer Bar....Leaking
rt & left sides....where it's bolted to aluminum crossmember....all around the insulators....black grease/ oil. any ideas?
Old Nov 20, 2005 | 08:10 PM
User 81424's Avatar
User 81424
It should have some grease on the rubber bushings to reduce noise, you may being see this.
Old Nov 20, 2005 | 08:57 PM
Z06ufgrad2002's Avatar
Z06ufgrad2002
you are probably seeing dirt that has collected in the lube used when it was installed.
Old Nov 20, 2005 | 09:25 PM
southerncarparts's Avatar
southerncarparts
Supporting Vendor
St. Jude Donor '06-'07, '13, '15
I have the same thing....nothing to worry about.
Jim
Old Nov 20, 2005 | 10:26 PM
LIGHTNING's Avatar
LIGHTNING
appreciate the info! thanks guys.
Old Nov 21, 2005 | 10:39 PM
Z06-Nomad's Avatar
Z06-Nomad
I think Redline makes a good synthetic stabilizer bar fluid.
Old Nov 22, 2005 | 01:32 AM
mqqn's Avatar
mqqn
Cruise-In III Veteran
Cruise-In IV Veteran
Cruise-In V Veteran
St. Jude Donor '03-'04-'05-'06-'07-'11
Hi Z06 Nomad -
best regards -
mqqn
To Rear Stabilizer Bar....Leaking
